gassergod Posted May 13, 2018 Report Share Posted May 13, 2018 Good morning could someone please explain the set up of these forks. the manual seems a bit confusing to me as they seem to get the info for each fork mixed up. I understand spring preload but what is the length ? Does anyone have any suggestions for sag etc on this bike. I am fairly new to all this and would like to get things sorted as well as i can many thanks Quote Link to comment Share on other sites More sharing options...
heffergm Posted May 13, 2018 Report Share Posted May 13, 2018 If you're new to trials the best thing you can do is leave them alone. Trials suspension is good out of the box. The best riders ride close to stock settings. Unless you weigh a ton or you're a little person, the stock setup will work well Quote Link to comment Share on other sites More sharing options...
cascao Posted May 14, 2018 Report Share Posted May 14, 2018 Take a look at this manual from formula Garfo formula regulagens.pdf Quote Link to comment Share on other sites More sharing options...
taff_d Posted July 16, 2018 Report Share Posted July 16, 2018 45-50mm front rider sag, 80-85mm rear rider sag, the rest is your personal choice on how you like the bike to feel. The bike come setup for "lighter" riders I'm 15 3/4 stone so use heavier springs. Quote Link to comment Share on other sites More sharing options...
