tyguy Posted May 29, 2018 Report Share Posted May 29, 2018 Before I go and spend a load of dosh on some Domino's - what levers do you guys recommend? I have these at the moment - but they don't feel right, lots of slop in the levers and the cable doesn't seem to run smooth in it (in any position) https://www.tytrials.co.uk/trailandtrialsuk/prod_47644-Clutch-Lightening-Lever-Forged.html TIA Quote Link to comment Share on other sites More sharing options...
b40rt Posted May 29, 2018 Report Share Posted May 29, 2018 (edited) There is slop in the lever of the 3 position shown above, but an acceptable compromise IMO. Good quality, well maintained and routed cables are essentially for a light clutch pull. Unless you have exceptionally large hands, domino's are a fair stretch for all day one finger clutch. If you don't use the clutch they are ideal and very good quality. Edited May 29, 2018 by b40rt Quote Link to comment Share on other sites More sharing options...
tyguy Posted May 29, 2018 Author Report Share Posted May 29, 2018 It's more that the clutch isn't engaging nicely, the lever seems to pulling the inner cable across a ridge rather than a nice straight run to the outer cable/adjuster. They are defo coming off, my clutch is a lot heavier than a friends TY which is all the same apart from the levers Quote Link to comment Share on other sites More sharing options...
feetupfun Posted May 29, 2018 Report Share Posted May 29, 2018 I've got genuine Suzuki RM80x clutch levers on a couple of Yamaha TYs. They are not cheap but good quality, bend not snap and are a great shape and reach for single finger clutch work 1 Quote Link to comment Share on other sites More sharing options...
jon v8 Posted May 29, 2018 Report Share Posted May 29, 2018 Domino on my bikes,not cheap but so comfy to use... 1 Quote Link to comment Share on other sites More sharing options...
pmk Posted May 29, 2018 Report Share Posted May 29, 2018 If it matters, my friend uses these on his 72 OSSA MAR. Forget his setup, but thought he used the hot start to activate his compression release, with it on the clutch side. Pretty certain, after he stalled and could not refire the motor on a downhill, I think he listened and moved the compression release to the brake side. None the less, he runs these levers. My OSSA uses the oem Amal levers, not endorsing them, just saying. https://msracing.com/hard-parts/controls/levers-and-perches/aof-clutch-lever-assembly.html Quote Link to comment Share on other sites More sharing options...
guy53 Posted May 30, 2018 Report Share Posted May 30, 2018 Many things to consider : the size of your hand, I have small hand, can't use some type of levers Type of grip : some are bigger than other. Do you run with one finger on the clutch to operate it Is your levers adjusted to your finger length, not only the '' slack '' in the cable, but the actual position of the lever on the bars Is your cable in good shape, I have on my TY 250b a lengthened arm under the motor and still had a hard clutch pull until I change the cable Guy 1 Quote Link to comment Share on other sites More sharing options...
pmk Posted May 30, 2018 Report Share Posted May 30, 2018 Agree, the OSSA requires the cable be cleaned and lubed constantly, and typically. Most times this is done the day before an event. Quote Link to comment Share on other sites More sharing options...
barfy Posted June 1, 2018 Report Share Posted June 1, 2018 (edited) I use Amal replica levers which are a bit cheaper than Domino. Agree though that the cable condition can make a lot of difference. Keep the cable well flushed with lubricant and replace if it looks kinked or has signs of fraying. Edited June 1, 2018 by barfy Quote Link to comment Share on other sites More sharing options...
