Pavloszx Posted June 4, 2018 Report Share Posted June 4, 2018 I have dismadled the clutch side to Change the crankcase seals and now i have this weird nocking Clutch seems to work okay didn't ride for more than a couple of minutes. Noise almost stops when i accelerate Below i have a link to a video with the noise. Could not upload a video. https://www.dropbox.com/sh/g1n1qzf9o9t37ko/AABc9GdBiMdEcrBWyTz-_oXMa?dl=0 Quote Link to comment Share on other sites More sharing options...
briangg Posted June 5, 2018 Report Share Posted June 5, 2018 (edited) Kinda funny you say noise is from clutch side and the video shows flywheel side. Not that it matters really cause its a noise but still. Hard to tell anything from the video Also id look for a small chip in all the gears behind clutch cover first as a chip will make a ton of noise. Edited June 5, 2018 by briangg Quote Link to comment Share on other sites More sharing options...
copemech Posted June 5, 2018 Report Share Posted June 5, 2018 I have listened to this and it is not apparent the issue, as they all rattle and worse sitting in neutral while revving. does it reduce when the clutch is in and in gear? there will be some rattle in the primary drive gears as well when unloaded. Quote Link to comment Share on other sites More sharing options...
feetupfun Posted June 5, 2018 Report Share Posted June 5, 2018 Before you pull anything apart, check for weird stuff like little rocks rattling against the bashplate or loose engine or bashplate bolts Quote Link to comment Share on other sites More sharing options...
Pavloszx Posted June 5, 2018 Author Report Share Posted June 5, 2018 15 hours ago, briangg said: Kinda funny you say noise is from clutch side and the video shows flywheel side. Not that it matters really cause its a noise but still. Hard to tell anything from the video Also id look for a small chip in all the gears behind clutch cover first as a chip will make a ton of noise. Could a chip in a gear be the cause to all of these rattle? Thanks for the reply!! Quote Link to comment Share on other sites More sharing options...
Pavloszx Posted June 5, 2018 Author Report Share Posted June 5, 2018 15 hours ago, copemech said: I have listened to this and it is not apparent the issue, as they all rattle and worse sitting in neutral while revving. does it reduce when the clutch is in and in gear? there will be some rattle in the primary drive gears as well when unloaded. No difference in gear or in neutral The only time it gets little less noisy is under load. Quote Link to comment Share on other sites More sharing options...
copemech Posted June 6, 2018 Report Share Posted June 6, 2018 4 hours ago, Pavloszx said: Could a chip in a gear be the cause to all of these rattle? Thanks for the reply!! absolutely! Quote Link to comment Share on other sites More sharing options...
briangg Posted June 6, 2018 Report Share Posted June 6, 2018 as copemech said absolutely. a small chip can cause all sorts of noise. make sure you closely look as it doesnt take much to cause the noise. check all of them on clutch side, basket and all. Quote Link to comment Share on other sites More sharing options...
scifi Posted June 6, 2018 Report Share Posted June 6, 2018 Listened to the video, do you mean that TATATATATA sound..? That seems to be occurring at crankshaft speed. If it was in the gear-box it would be 3.5 times slower, TA.......…. TA...….…. TA...….. because of the primary gear reduction. Had a Honda 125 that was making a very slow knocking noise, that turned out to be some rollers missing from the timing chain, a reduction of about 6 to 1. ( length of chain divided by size of cog.) So it could be something with the Piston.. loose small-end.? or broken ring ? Or maybe something in the induction system.. Noisy reeds.? carb slide worn..? It might get better with use, but it might get worse.... ! . Quote Link to comment Share on other sites More sharing options...
Pavloszx Posted June 8, 2018 Author Report Share Posted June 8, 2018 On 6/6/2018 at 3:25 AM, copemech said: absolutely! Thank you for the reply again I have found some chipping Should i file them smooth? Quote Link to comment Share on other sites More sharing options...
tony27 Posted June 8, 2018 Report Share Posted June 8, 2018 If you have chipping then the gear needs replacing, will only get worse if you don't Quote Link to comment Share on other sites More sharing options...
