slip_kid Posted June 8, 2018 Report Share Posted June 8, 2018 91053-ND9-000 What are RTL owners doing for a replacement when the original is worn out? Yes I know the RS125R uses the same in the top position, but that information doesn't seem to be of any help. Quote Link to comment Share on other sites More sharing options...
petert Posted June 8, 2018 Report Share Posted June 8, 2018 https://bidsonmotors.com/en/91053ND9000 Quote Link to comment Share on other sites More sharing options...
slip_kid Posted June 8, 2018 Author Report Share Posted June 8, 2018 I noticed them before I posted this question. Did you know them to actually have any inventory? Have you made a recent purchase? Thanks. Quote Link to comment Share on other sites More sharing options...
slip_kid Posted June 8, 2018 Author Report Share Posted June 8, 2018 I found a person modifying taper bearing for use in the RS125R. That bike only uses it in the top. He gave me a measurement to check on my RTL head stock. If I have the clearance his part should work. It may take a week to get back to this, but once I know something one way or the other I'll update this post. If anyone else should have useful input on this subject please respond. Thank you. Quote Link to comment Share on other sites More sharing options...
Eddie Strickland Posted January 3, 2019 Report Share Posted January 3, 2019 Hello all, I've just joined as I have the same Bearing issue. I am changing the forks (as I don't have the top clamp and stem) to USD Derbi forks. The method I am employing is this; Measure stem width. Mine is 25 mm at bottom and top. (RS 125 stem is NOT 25mm top and bottom but it is same as Measure Honda RS 125 NF4 steering tube, this is 55 mm bottom and 47 mm top the old ball races depth is 12 mm at bottom and 8 mm top. The problem is Honda doesn't make/supply these parts for RTL or RS respectively https://www.cmsnl.com/honda-rtl250s-1985-1986-hrc_model35475/partslist/0092.html#.XC5Yglz7S00 http://tso.us.com/parts-book/honda/0125rs125/1989/3_part_pages/f_02.asp What i'm in the process of doing is first find bearing to suit stem then to suit outside diameter. https://uk.rs-online.com/web/c/pneumatics-hydraulics-power-transmission/power-transmission-rotary-bearings/ball-bearings/?applied-dimensions=4294845448,4294845461 gives some alternative bearings for my 25 mm stem with/without seals. NOTICE these are ball bearings for the bottom and is 12 mm thick. https://www.ebay.co.uk/i/321858810549?chn=ps 15mm thick this gives a ball bearing for the top. these bearings are too thick for standard replacement. This issue was discussed by Kiwi Biker https://www.kiwibiker.co.nz/forums/showthread.php/181289-NF4-steering-head-bearings(RS125-88-94) for me im in the process of using taper bearings as they fill in the gap between the Derbi Forks and the Honda steering tube. https://www.bearingstation.co.uk/products/Bearings/Taper_Roller_Bearing/Metric_Tapered_Roller To get original ball bearings in it is a case of sourcing the correct size of bearing and get them skimmed/ground down. Ed Quote Link to comment Share on other sites More sharing options...
slip_kid Posted January 3, 2019 Author Report Share Posted January 3, 2019 (edited) Hi Ed, I've had to put this project aside though I did buy modified taper bearings from: Leonard Technical Sports One 9920 Prospect Ave Suite107 Santee, CA 92071-4349 U.S.A. (619) 258-0125 (619) 258-1450 fax sales@tso.us.com http://www.tso.us.com/ These modified bearings have the frame (steer tube ID) clearance necessary to work in my '85 RTLS. I couldn't speak to other bikes, but Leonard can provide the measurement specs so you can check your specific bike. One other thing I recent discovered that has seemingly never been discussed in this forum. A Cota 4RT yoke and factory Honda part number bearings fit w/o any issue in the pre-disc brake RTL250S. Yes I'm aware this is an issue for some riders in certain classes. I also can't say this fitment works in the disc brake RTL250S ('88-'90). Doug Edited January 3, 2019 by slip_kid Quote Link to comment Share on other sites More sharing options...
fantic303 Posted January 7, 2019 Report Share Posted January 7, 2019 a possibility is https://www.123roulement.com/roulement-SAC2647-1-KOYO.php or https://www.123roulement.com/roulement-SF0581PX1-NTN.php ground the innerring to 9mm hight and you have a real copy of the original one. Quote Link to comment Share on other sites More sharing options...
slip_kid Posted January 7, 2019 Author Report Share Posted January 7, 2019 Thanks Fantic303. Those are very useful links for as near to the real thing as is possible. They have a US division so ordering is a snap. Quote Link to comment Share on other sites More sharing options...
