Varlo Posted June 12, 2018 Report Share Posted June 12, 2018 Hi, are there any other Yamaha fork tubes compatible with ty250 twinshock? There seams an abundance of dt & Rd tubes but nothing for ty. Quote Link to comment Share on other sites More sharing options...
feetupfun Posted June 13, 2018 Report Share Posted June 13, 2018 New tubes for TY250 twinshock are available, or are you after 2nd hand? Quote Link to comment Share on other sites More sharing options...
Varlo Posted June 13, 2018 Author Report Share Posted June 13, 2018 I was after new, the ones I can find for ty are double price of other 70s yams Quote Link to comment Share on other sites More sharing options...
section swept Posted June 13, 2018 Report Share Posted June 13, 2018 (edited) Hi Varlo, I’m over in Mansfield and recently rebuilt a TY250E many of the spares I needed came from yambits, they don’t show the fork tubes but I’m sure if you were to ask they may be able to source at the right money. Very helpful to me when I needed advice on parts. Franks forks also may be able to make you some. Edited June 13, 2018 by section swept 1 Quote Link to comment Share on other sites More sharing options...
faussy Posted June 13, 2018 Report Share Posted June 13, 2018 Is re-chroming your own out of the question? Quote Link to comment Share on other sites More sharing options...
Varlo Posted June 13, 2018 Author Report Share Posted June 13, 2018 Hi, I'm on outskirts of mansfield! Not too far away. I'll give yambits a call tomorrow, I spoke to a company today that makes fork tubes for just about every 70s bike apart from ty. The only reason I wanted new is because they say 3 weeks to complete, & I didn't want to be off bike that long. Quote Link to comment Share on other sites More sharing options...
teamferret Posted June 14, 2018 Report Share Posted June 14, 2018 As I recall, the RD tubes are a smaller diameter at the bottom. Most 35mm scrambles or trials fork tubes should fit, I've fitted Marzochi ones into loads of different bottoms Quote Link to comment Share on other sites More sharing options...
feetupfun Posted June 14, 2018 Report Share Posted June 14, 2018 1 hour ago, teamferret said: As I recall, the RD tubes are a smaller diameter at the bottom. Most 35mm scrambles or trials fork tubes should fit, I've fitted Marzochi ones into loads of different bottoms except TY and RD forks are 34 mm not 35 mm 1 Quote Link to comment Share on other sites More sharing options...
teamferret Posted June 14, 2018 Report Share Posted June 14, 2018 That didn't stop me, the hardest part was setting the fork bottom up in the lathe. Quote Link to comment Share on other sites More sharing options...
section swept Posted June 14, 2018 Report Share Posted June 14, 2018 Re-chroming or in the case of fork tubes hard chroming is usually the way to go, there’s a company in Hull that offers a service. Maybe some more locally, certainly one or more in Mansfield. If you need to ride and want to use your current tubes, you could rub down the affected areas and fill any imperfections with Araldite or similar Epoxy resin filler, rub down again with wet and dry and away you go...the seals may suffer but hey you are at least riding. This although sounding like a bodge it does actually work.? 1 Quote Link to comment Share on other sites More sharing options...
