spud Posted December 25, 2005 Report Share Posted December 25, 2005 A very good bike and i'd recommend it to anyone. I had the 03 from new and the only niggles were the back brake locked on, the footrests are very stiff and I personally found the bars a little low. The engine induction noise needed getting used too. To ride the bike was smooth and powerful and jumping off a Beta 270 onto the Scorpa (no ***t) I thought Scorpa had more power! Quote Link to comment Share on other sites More sharing options...
scorpa-usa Posted December 26, 2005 Report Share Posted December 26, 2005 The honest weight for the SY 250 two stroke is 162 lbs. without gas. The 01 and 02 models weighed about 1.5 lbs. more than that because the hubs and rims were different having more spokes and more anchor points for the sprocket and brakes. Almost every manufacture went from the 36 spoke wheels and hubs to the 32. Quote Link to comment Share on other sites More sharing options...
austini Posted December 27, 2005 Report Share Posted December 27, 2005 Having just bourght a 04 sy I have nothing but praise for it, however she does have a tendency to stall at the lower revs, a problem I didn't suffer with my previous sherco. Evidently retarding the timing back to original Yamaha settings is the way to fix this minor hicup! once i've tried it i'll let you all know how I got on. On the plus side it cost me over $200 (aus) to replace the multitude of bearings to bring the sherco's rear end up to spec and it still has play in it. The scorpas rear end has not one iota of play and with the limited amount of moving parts should be a major saving come the yearly rebuild. (if she needs one at all) Quote Link to comment Share on other sites More sharing options...
sparky Posted December 29, 2005 Report Share Posted December 29, 2005 Just bought an 06 sy 250 after 11 years on gas gas 250 and 200.For me as a clubman they are very easy to ride, plenty of grip, bags enough power.The water pump can have a guard around it but there is an aftermarket waterpump cover with a different angle for the pipe which also cures the problem. Also the carb comes off without taking the airbox off, its only a 10 minute job just reroute your throttle cable. Hope this helps in your desision Quote Link to comment Share on other sites More sharing options...
lastplacebrad Posted December 29, 2005 Report Share Posted December 29, 2005 sparky said: Just bought an 06 sy 250 after 11 years on gas gas 250 and 200.For me as a clubman they are very easy to ride, plenty of grip, bags enough power.The water pump can have a guard around it but there is an aftermarket waterpump cover with a different angle for the pipe which also cures the problem. Also the carb comes off without taking the airbox off, its only a 10 minute job just reroute your throttle cable. Hope this helps in your desision <{POST_SNAPBACK}> This i NEED to know!! info please! Quote Link to comment Share on other sites More sharing options...
arnoux Posted December 31, 2005 Report Share Posted December 31, 2005 (edited) Brad if you really need to know............ http://www.bemotrial.de/bemoframe.htm look under special items then Scorpa . You'll find the trick W/P replacements. Why don't you try the old BETA Rev 3 coil cover slightly modified - works a treat! Edited December 31, 2005 by arnoux Quote Link to comment Share on other sites More sharing options...
jools Posted January 5, 2006 Report Share Posted January 5, 2006 lastplacebrad said: sparky said: Also the carb comes off without taking the airbox off, its only a 10 minute job just reroute your throttle cable. Hope this helps in your desision <{POST_SNAPBACK}> This i NEED to know!! info please! <{POST_SNAPBACK}> I was up at Birkett's yesterday and he mentioned this as a mod they do. He said they heat up the elbow at the top of the carb and bend it straight and route the throttle cable over the frame. Supposedly the slide comes out really easily and you can slip the carb out. Best bet is to phone them, He is really helpful! Quote Link to comment Share on other sites More sharing options...
sparky Posted January 5, 2006 Report Share Posted January 5, 2006 yep thats the way. He did it to mine now its a piece of p*** to do.I do clean it out before every trial mind you theres never any water or muck in it so probably wasting valuble polishing time Quote Link to comment Share on other sites More sharing options...
bikespace Posted January 5, 2006 Report Share Posted January 5, 2006 (edited) Jools said: I was up at Birkett's yesterday and he..... <{POST_SNAPBACK}> Hmmmm....Birkett's eh? Bit of a trip? Just fancy a day out? 06 Gasser not floating your boat yet? Scorpa swap on the horizon? Just rumour mongering Edited January 6, 2006 by bikespace Quote Link to comment Share on other sites More sharing options...
nigel dabster Posted January 6, 2006 Report Share Posted January 6, 2006 sparky said: yep thats the way. He did it to mine now its a piece of p*** to do.I do clean it out before every trial mind you theres never any water or muck in it so probably wasting valuble polishing time <{POST_SNAPBACK}> Which scorpa do you have Sparky? Quote Link to comment Share on other sites More sharing options...
downunder Posted January 6, 2006 Report Share Posted January 6, 2006 Hi all Seasons greetings and all that stuff. The only thing I really found odd with a Scorpa was the frontend set up. To start with it felt floppy (too much caster)and harder to balance than the Sherco/GG's. After getting used to the different feel I love it! It tracks and and front hops (only to the right....still working on hopping left)and I can hold it when the front wants to wash out. Only thing I can recommend to change is that superbly made bashplate........ditch it and buy a flat one!!!! We did lean my 04 down a tad on the main jet and that gave it "S" loads of lift and between sections it monos through whoops like a gem Other than that, is there a sweeter bike to ride???? I think not Quote Link to comment Share on other sites More sharing options...
jools Posted January 6, 2006 Report Share Posted January 6, 2006 bikespace said: Jools said: I was up at Birkett's yesterday and he..... <{POST_SNAPBACK}> Hmmmm....Birkett's eh? Bit of a trip? Just fancy a day out? 06 Gasser not floating your boat yet? Scorpa swap on the horizon? Just rumour mongering <{POST_SNAPBACK}> ........ dunno...... Take a look at the clasifieds.......! Quote Link to comment Share on other sites More sharing options...
dfwilson Posted January 6, 2006 Report Share Posted January 6, 2006 sparky said: Just bought an 06 sy 250 after 11 years on gas gas 250 and 200.For me as a clubman they are very easy to ride, plenty of grip, bags enough power.The water pump can have a guard around it but there is an aftermarket waterpump cover with a different angle for the pipe which also cures the problem. Also the carb comes off without taking the airbox off, its only a 10 minute job just reroute your throttle cable. Hope this helps in your desision <{POST_SNAPBACK}> Sparky, Some time when you have the tank off would you please take a picture and post it to show how you re-routed the throttle cable. Thanks Doug Wilson Quote Link to comment Share on other sites More sharing options...
