Shock mounting bosses.
hoodie2
Got a Bultaco Sherpa m80 project. The swinging arm has two badly rusted bolts welded on for shock mounting. Don't really want shock bushes running on a course thread. Does anyone know if you can buy weld on threaded bosses or get the right size threaded bar or will I have to get something made up?
Cheers.
I once modified the bottom shock mounts on my Fantic 300 swingarm by using "clevis pins" in the 12mm diameter that I required and simply cut them down to the length needed and drilled and tapped a 6mm thread down the centre for the shock retaining screw and then mig welded them in place. It worked a treat and I'm only an average welder and don't have a drill press either and I'm still riding the Fantic occasionally to this day. Hope this is helpful.
  • Like 2
