John Svoboda Posted March 13, 2019 Report Share Posted March 13, 2019 (edited) On 7/3/2018 at 6:41 PM, jmurray443 said: I have a 2017 Fajardo 300 and had trouble starting it along with it stalling it turned out the fuel pump was bad (low pressure), although its still a little cranky to start at times I think that's just the nature of the beast replacing the kick lever with the 2018 lever helped a little. jmurray443 I have a Fajardo 300 too.How many kicks cold and warm does it take to start with the new pump?Mine is 4/5 cold and 1/2 warm if restarted within a few minutes of riding. Was also wondering if your rear shock was set up to specification. I have never checked mine. Cheers John Edited April 3, 2019 by John Svoboda Quote Link to comment Share on other sites More sharing options...
jsp Posted March 14, 2019 Report Share Posted March 14, 2019 14 hours ago, John Svoboda said: jmurray443 I have a Fajardo 300 too.How many kicks cold and warm does it take to start with the new pump?Mine is 4/5 cold and 1/2 warm if restarted within a few minutes of riding. Was also wondering if your rear stock was set up to specification. I have never checked mine. Cheers John John I have a Fajardo 250 and mine takes about the same amount of kicks yours does to start, I've checked my rear shock and it was set up correctly Quote Link to comment Share on other sites More sharing options...
John Svoboda Posted March 28, 2019 Report Share Posted March 28, 2019 On 3/14/2019 at 1:13 AM, jsp said: John I have a Fajardo 250 and mine takes about the same amount of kicks yours does to start, I've checked my rear shock and it was set up correctly Thank you for the information Quote Link to comment Share on other sites More sharing options...
A_ekis Posted March 29, 2019 Report Share Posted March 29, 2019 On 3/13/2019 at 6:43 PM, John Svoboda said: jmurray443 I have a Fajardo 300 too.How many kicks cold and warm does it take to start with the new pump?Mine is 4/5 cold and 1/2 warm if restarted within a few minutes of riding. Was also wondering if your rear stock was set up to specification. I have never checked mine. Cheers John I also have a fajardo 300. In cold starts always at 3, although you give strong or slow, always at 3 (it is logical, to have to take pressure in the injector and others) in hot, if it takes less than 3 or 4 minutes to stop, to kick 1. if it takes a little more time to the second kick Quote Link to comment Share on other sites More sharing options...
