taff_d Posted July 1, 2018 Report Share Posted July 1, 2018 Is there such a thing on the market as a intermediate throttle tube ? The new bike came with a fast action which I liked in most sections today but in a couple it was a bit quick and got away from me. I have tried my slow acton Xblox on it and did not like it as much as the fast. Quote Link to comment Share on other sites More sharing options...
jonnyc21 Posted July 1, 2018 Report Share Posted July 1, 2018 (edited) Unless they stopped making them they did have a company that did some various throttle tube versions. I will see if I can find the information on the company and post it if I do. if so I see you have two options, one is pick up one from them, or cut down a fast tube yourself. if you take a black slow tube and compare to a white you should see that the difference is just the diameter of the tube where the cable sits when twisted. You can custom your own by filing a small amount off of a white tube yourself. Good luck! Edited July 1, 2018 by jonnyc21 1 Quote Link to comment Share on other sites More sharing options...
jonnyc21 Posted July 1, 2018 Report Share Posted July 1, 2018 It has been a long time sense I checked into it so I am not sure if this is the same thing I found last time but the concept is the same and maybe you can get the correct version for your usage. https://www.g2ergo.com/store/g2-throttle-cam-system/ or maybe http://www.rollonthrottle.com/specialorder.html I also found this one, but dosn't look like it would work for most standard Domino trials bike setups. https://www.motionpro.com/c/rev2-throttle Quote Link to comment Share on other sites More sharing options...
jrsunt Posted July 1, 2018 Report Share Posted July 1, 2018 As J21 says, custom make your own. File the white or add to the black. 1 Quote Link to comment Share on other sites More sharing options...
nigel dabster Posted July 3, 2018 Report Share Posted July 3, 2018 jon other way round? Quote Link to comment Share on other sites More sharing options...
taff_d Posted July 15, 2018 Author Report Share Posted July 15, 2018 Added metal to my No1 X Blox but was still a bit slow but a lot better than a slow action, managed to source a No 2 X Blox and it's just what I was looking for ? 1 Quote Link to comment Share on other sites More sharing options...
stpauls Posted October 12, 2018 Report Share Posted October 12, 2018 Just out of interest. I have a slow throttle fitted. I wonder if you can get/make an even slower throttle? Quote Link to comment Share on other sites More sharing options...
jonnyc21 Posted October 15, 2018 Report Share Posted October 15, 2018 On 10/12/2018 at 8:23 AM, stpauls said: Just out of interest. I have a slow throttle fitted. I wonder if you can get/make an even slower throttle? The smaller the diameter of the section the cable wraps around the slower the throttle, so by that logic if you can file down the shoulder the cable sits on you can make it slower. The limit is of course is just a touch larger than the size of the bar... Quote Link to comment Share on other sites More sharing options...
