oni nou Posted July 23, 2018 Report Share Posted July 23, 2018 On 20/07/2018 at 3:36 PM, heffergm said: So warmed the bike up a few minutes (it doesn't make the sound when completely cold), pulled the plug, and the noise is still there. I'm mystified, mainly because it's impossible to pinpoint where the noise is coming from. I've heard from one person that says that have the same noise, and has continued to ride it with no sign of mechanical issues, so I'm inclined to do the same for the time being. I'll see about getting a mechanics stethoscope to help locate the sound. Rear brake pads squeaking when the bike moves around while kicking it ? Quote Link to comment Share on other sites More sharing options...
heffergm Posted July 23, 2018 Author Report Share Posted July 23, 2018 46 minutes ago, oni nou said: Rear brake pads squeaking when the bike moves around while kicking it ? Nope. Quote Link to comment Share on other sites More sharing options...
miner Posted July 24, 2018 Report Share Posted July 24, 2018 Squeak Squeak Quote Link to comment Share on other sites More sharing options...
heffergm Posted July 24, 2018 Author Report Share Posted July 24, 2018 I'd like to hear that with you just pushing the kicker through its stroke a few times, but to me, it seems a lot more mechanical sounding than what I'm hearing on mine. Quote Link to comment Share on other sites More sharing options...
section swept Posted July 24, 2018 Report Share Posted July 24, 2018 On 20/07/2018 at 12:16 PM, Nebulous said: 2860.278. Easy! Bet you used a calculator ?? Quote Link to comment Share on other sites More sharing options...
heffergm Posted July 27, 2018 Author Report Share Posted July 27, 2018 FYI, turned out to be the water pump. 1 Quote Link to comment Share on other sites More sharing options...
section swept Posted July 27, 2018 Report Share Posted July 27, 2018 2 hours ago, heffergm said: FYI, turned out to be the water pump. As I suggested, try some new anti freeze of the correct type. You might also try dropping in a small amount of silicon fluid if the noise persists. It might also be a sign that there is wear in the bearing, worth removing the pump and checking thoroughly? Quote Link to comment Share on other sites More sharing options...
heffergm Posted July 27, 2018 Author Report Share Posted July 27, 2018 I'll be replacing it, but the antifreeze is already correct (Maxima Coolanol, it's used rather ubiquitously in motorcycles with aluminum and mag cases). 1 Quote Link to comment Share on other sites More sharing options...
section swept Posted July 28, 2018 Report Share Posted July 28, 2018 If you are intending to keep the old pump as a spare then coat it with silicon spray and place the pump in a plastic bag. This will keep the seal from drying out and sticking to the shaft. May even stop the squeak. Quote Link to comment Share on other sites More sharing options...
