Oset Lanyard not closing circuit
balga
Hi,
just tried to connect an oset lanyard to my son 16”.
I tried a petrol bike one and that was working backwards, so changed it for a Oset one.
now, when I connect it it does not work at all, why is that?
What I did was removing the key switch which was not needed and connected the two wires straight into the lanyard wires.
shoulnt the oset lanyard close a circuit between the two wires when it’s clipped on?
what am I missing?
the bike is an older model equipped with Kelly controller and OEM throttle
Edited by balga
Duff kill switch, been covered before about a week back. Reconnect ignition switch and confirm everything good. Test kill switch with a torch battery and bulb a simple circuit to confirm kill switch is good or duff. You could use a DVM to test the switch if you have one.
Edited by section swept
  • Thanks 1
ok, thanks
from the test that I've done it does not close the circuit in any way.
I guess my doubt was that instead of being just an on/off breaker, there could have been some other component inside the button that would have shut off the bike in another way - not an expert in electrical components.
If it is definitely just a on/off breaker it's just defective then
