gasgasssser Posted January 20, 2006 Author Report Share Posted January 20, 2006 hey magic matt,those needle rollers...cant tell you how much they were `cos i sneakily got them through work from a bearing dealer,but i remember they are a non-standard item,whicm means if you want complete renewal,you have to go to gasgas.The inner bush is smller than the std item so that it takes a 6mm(or is it 8mm?)bolt.Mine(inner bush) wernt that worn so i binned the std inners and used the original ones. Quote Link to comment Share on other sites More sharing options...
gasgasssser Posted January 20, 2006 Author Report Share Posted January 20, 2006 hey magic matt,those needle rollers...cant tell you how much they were `cos i sneakily got them through work from a bearing dealer,but i remember they are a non-standard item,whicm means if you want complete renewal,you have to go to gasgas.The inner bush is smller than the std item so that it takes a 6mm(or is it 8mm?)bolt.Mine(inner bush) wernt that worn so i binned the std inners and used the original ones. :marky Quote Link to comment Share on other sites More sharing options...
charliechitlins Posted January 21, 2006 Report Share Posted January 21, 2006 Motorcycle repair in a tube! I love it when the cheapest/easiest way works! Quote Link to comment Share on other sites More sharing options...
