Masterbeta808 Posted July 25, 2018 Report Share Posted July 25, 2018 Hi, I have what i think is a 1995 or 1994 beta techno 250 and it has a dellorto carb and it continues to overflow. I have replaced the float needle and the needle seat and i have replaced the floats aswell but when i tried bending the tabs it would either overflow or it wouldnt get any gas at all. Im stumped on what to do im not sure if i need to replace the carb or what. Quote Link to comment Share on other sites More sharing options...
inchhigh Posted July 25, 2018 Report Share Posted July 25, 2018 you've not got the floats in upside down?? I've done that before Quote Link to comment Share on other sites More sharing options...
reggie Posted July 25, 2018 Report Share Posted July 25, 2018 Sometimes the d/o floats do not float, this may be your problem. Quote Link to comment Share on other sites More sharing options...
Masterbeta808 Posted July 25, 2018 Author Report Share Posted July 25, 2018 I have checked to make suee the floats float and also i believe i have them in correctly with the pins on the float towards the bottom Quote Link to comment Share on other sites More sharing options...
section swept Posted July 25, 2018 Report Share Posted July 25, 2018 (edited) Maybe you need to start again. Remove float bowl and make sure it is not distorted, in other words useca straight edge across its mating surface. Now ensure by referring to or checking against a parts list that you have everything you’re supposed to have in the carb. With the carb assembled gently blow into the fuel entry point with your mouth and with your finger gently hold the float against the needle valve, if you can’t stop your breath from entering the fuel entry point then there obviously is something seriously wrong with either your fitting or those parts fitted. Let the float drop a little, lift it back up to prove it works as it should. If there is a tickler plunger make sure it’s not stuck down. There was a need for a carb mod on later models, could be worth checking out. Edited July 25, 2018 by section swept Quote Link to comment Share on other sites More sharing options...
Billywhiz Posted July 26, 2018 Report Share Posted July 26, 2018 I had the same problem with a phbh on my alpina. The solution came from a karting site. If there is vent pipe, going from a spigot on one side to the same type on the other side, it should have a slit in it. Mine had been 'repaired' with a joint, I drilled a 0.5mm hole and bingo. Quote Link to comment Share on other sites More sharing options...
Masterbeta808 Posted July 26, 2018 Author Report Share Posted July 26, 2018 On 7/26/2018 at 9:01 PM, Billywhiz said: I had the same problem with a phbh on my alpina. The solution came from a karting site. If there is vent pipe, going from a spigot on one side to the same type on the other side, it should have a slit in it. Mine had been 'repaired' with a joint, I drilled a 0.5mm hole and bingo. Expand When you say a slit do you mean in the tubing or in the actual pipe? Because there are two vent pipes that are connected by one hose are you saying the hose needs a hole in it? Quote Link to comment Share on other sites More sharing options...
oni nou Posted July 26, 2018 Report Share Posted July 26, 2018 On 7/26/2018 at 9:05 PM, Masterbeta808 said: When you say a slit do you mean in the tubing or in the actual pipe? Because there are two vent pipes that are connected by one hose are you saying the hose needs a hole in it? Expand Half way along the tube cut half of the tube away with a scalpel/Stanley knife to a length of approx. 2 cm ......this will allow air [atmospheric pressure] to enter the chamber above the fuel in the float bowl ..........if air cannot enter there [because the vents have been blocked by a piece of unvented tubing] at atmospheric pressure fuel cannot be sucked through the carb jets to supply the motor. Its a common mistake made by people who do not understand how a carburettor works. Quote Link to comment Share on other sites More sharing options...
Masterbeta808 Posted July 26, 2018 Author Report Share Posted July 26, 2018 On 7/26/2018 at 9:21 PM, oni nou said: Half way along the tube cut half of the tube away with a scalpel/Stanley knife to a length of approx. 2 cm ......this will allow air [atmospheric pressure] to enter the chamber above the fuel in the float bowl ..........if air cannot enter there [because the vents have been blocked by a piece of unvented tubing] at atmospheric pressure fuel cannot be sucked through the carb jets to supply the motor. Its a common mistake made by people who do not understand how a carburettor works. Expand Thank you that solved the problem it nakes sense how if theres no ventilation that it wont run i noticed it when we first got it abiut why they were connected to eachother but i just left it alone and thought nothing of it Quote Link to comment Share on other sites More sharing options...
copemech Posted July 27, 2018 Report Share Posted July 27, 2018 you will be far better off if you simply remove the connected vent hose entirely or just use a short section on either side to act as a crap deflector because that is all it really does Quote Link to comment Share on other sites More sharing options...
Masterbeta808 Posted July 27, 2018 Author Report Share Posted July 27, 2018 The bike ran for a little bit but now there is no spark ive disconnected the kill switch and it wasnt that and it has a new plug aswell i havent started testing yet but i will try tomorrow Quote Link to comment Share on other sites More sharing options...
