Front wheel removal
Fatboydel888
 Ok, finally had some free time, drained the old fuel, changed the air filter and she fired up first kick, long may that continue ?
‘still cannot get neutral, no matter what I try, have to turn it off and it is still difficult, Judy pops between first and second and back, no matter how careful I am.
No, not required. Just lean the bike on its side, then remove the clutch cover. Once the cover is removed you will have to remove the clutch basket to access the adjuster bolt. There's a very good video by Jim Snell which takes you through the steps. Best to find it and watch it first as there are a few "tricks"; there's a washer which you need to keep track of, along with a special hollow bolt. Nothing too difficult.
Hope it helps with your neutral issue.
