mattmahon10 Posted August 8, 2018 Report Share Posted August 8, 2018 Hi all, Can anyone tell me what liquid to use in the clutch for a 2008 4rt? my cap says mineral oil and it had a green seal underneath however everywhere i look it suggests that it should be dot 4? Im wondering if a previous user swapped the cap out for whatever reason. Thanks Matt Quote Link to comment Share on other sites More sharing options...
jonnyc21 Posted August 8, 2018 Report Share Posted August 8, 2018 I have both an 2007 and a 2017 and both use Dot 4. I am almost sure you have a swapped cap unless someone also changed out the master on you... Quote Link to comment Share on other sites More sharing options...
peterb Posted August 9, 2018 Report Share Posted August 9, 2018 You can always check the oil type, mineral oil has a definite oily feel, slippery. DOT 4 has more of a watery much less slippery feel. It would be unusual for someone to change the master cylinder kit to mineral and then the slave cylinder seals too. Bye, Peter B. 1 Quote Link to comment Share on other sites More sharing options...
