Twinshockandy Posted August 9, 2018 Report Share Posted August 9, 2018 Can anyone give me an idea if an early cota 123 engine will fit into a later cota 200 frame........( and all 123 ancillaries swap over), although I realise exhaust/silencer is different) Reason for asking is at present running 123 with 400x18 rear tyre, which is rubbing, (still using 123 swing arm, as not been able to find a 172 arm)..and the '200', I believe was the later version of the 172 with the wider swing arm. Any idea's ? Quote Link to comment Share on other sites More sharing options...
feetupfun Posted August 10, 2018 Report Share Posted August 10, 2018 If you post up the dimensions and a photo of your 123 swingarm, you might find that someone will have a look at their trials bikes to see if the swingarm from something else (other than a 172) will fit. 1 Quote Link to comment Share on other sites More sharing options...
brewtus Posted August 14, 2018 Report Share Posted August 14, 2018 Not trying to spend your money for you, but did you try AJG and see if they can help you out? Google "AJG Twinshock" and you'll find 'em on FaceTube (whatever), as the link evidently isn't allowed here. Trick stuff there.... 1 Quote Link to comment Share on other sites More sharing options...
Twinshockandy Posted August 14, 2018 Author Report Share Posted August 14, 2018 8 hours ago, brewtus said: Not trying to spend your money for you, but did you try AJG and see if they can help you out? Google "AJG Twinshock" and you'll find 'em on FaceTube (whatever), as the link evidently isn't allowed here. Trick stuff there.... Thanks brewtus.....interesting Quote Link to comment Share on other sites More sharing options...
brewtus Posted August 15, 2018 Report Share Posted August 15, 2018 Pure sexiness. This one is for a Beamish, posted in that forum - I try not to see if they have neat stuff for 247s and 348s.... 1 Quote Link to comment Share on other sites More sharing options...
Twinshockandy Posted August 15, 2018 Author Report Share Posted August 15, 2018 23 minutes ago, brewtus said: Pure sexiness. This one is for a Beamish, posted in that forum - I try not to see if they have neat stuff for 247s and 348s.... Think your safe, there.......spoken with him, and he's not done anything for Montesa........yet. Quote Link to comment Share on other sites More sharing options...
