Beta SSDT Waterproofing Recommendations
mcman56
Lampkins have a couple of pages of recommendations for SSDT preparations.  One of these is a piece of foam pushed down between frame and front of air box by the top of the shock on an evo.  This will cause it to touch the top of the muffler.  How do you ensure it does not melt or catch fire?
Buy fire retarding reticulated foam and cut the foam in a shape that does not touch the muffler and if you are still worrying then use some heat shield in between the foam and the muffler.....basically just use common sense really.
