Rich-B Posted August 18, 2018 Report Share Posted August 18, 2018 Hi bike kicks up fine and runs sweet off the choke then as soon as it starts to get up to temp about the point I get on it to ride it just bogs down when I blip the throttle or cuts out! Is there anywhere I can find the factory carb mixture and tick over screw settings or what do people recommend? carb has been cleaned, tank cleaned, new fuel tap and filter, balancing pipe ok no other obvious air leaks cheers Rich Quote Link to comment Share on other sites More sharing options...
zerorev3rev4 Posted August 18, 2018 Report Share Posted August 18, 2018 Will it keep running with choke? Quote Link to comment Share on other sites More sharing options...
Rich-B Posted August 18, 2018 Author Report Share Posted August 18, 2018 Iv not put the choke on when hot, il try that, what would that indicate? Quote Link to comment Share on other sites More sharing options...
oni nou Posted August 18, 2018 Report Share Posted August 18, 2018 (edited) 4 hours ago, Rich-B said: Hi bike kicks up fine and runs sweet off the choke then as soon as it starts to get up to temp about the point I get on it to ride it just bogs down when I blip the throttle or cuts out! Is there anywhere I can find the factory carb mixture and tick over screw settings or what do people recommend? carb has been cleaned, tank cleaned, new fuel tap and filter, balancing pipe ok no other obvious air leaks cheers Rich Clic on this. https://youtu.be/QT7XK4123hI Your carb has fuel flow problems ...probably the pilot jet is blocked or restricted or you have other fuel flow to the carb float bowl problems . There is no balancing pipe if you have a pipe running from 1 breather on the slide tower to the other and they are not vented then that is your problem. Your bike should be running with a 2t oil mix of 80:1 or 12.5 cc of fully synthetic oil to 1 litre of petrol this is not up for question its a don't tell your grandma's[plural]how to suck eggs thing. Edited August 18, 2018 by oni nou 1 Quote Link to comment Share on other sites More sharing options...
Rich-B Posted August 18, 2018 Author Report Share Posted August 18, 2018 Thanks il check out the link and take your points on board to see if it helps my situation, cheers Rich ???? Quote Link to comment Share on other sites More sharing options...
b40rt Posted August 22, 2018 Report Share Posted August 22, 2018 Try all the above first. Does it restart when hot ? If not you could have an ignition issue. Quote Link to comment Share on other sites More sharing options...
Rich-B Posted August 27, 2018 Author Report Share Posted August 27, 2018 I have changed the spark plug as it wasn’t quite the correct one fitted! I had it running up to temp today and it was running but hunting a bit so after some slight tuning on the mixture Iv had it running really well at normal running temperature, thanks for all the advice ?? Quote Link to comment Share on other sites More sharing options...
