misterroy Posted August 22, 2018 Report Share Posted August 22, 2018 It usually happens going downhill, a misjudgement and I stall the bike. If I can kick it within about 3 seconds it has a good chance of starting, but often I am not in a good position to kick it immediately. If it is getting to ten seconds I might have to wait for it to cool off before I can start it. I know part of the problem is my kick, which is improving, but the amount of muscle in my leg is not what it was. If the bike is cold I put on the choke, push the kick start gently a couple of times to suck some fuel in, then give it a kick to start it. This works for the first start of the day, and will work if I let the bike get cold after stalling while out riding. The gap at the plug is 0.5mm. Anything mechanical I can do to make it start after a stall? Quote Link to comment Share on other sites More sharing options...
2stroke4stroke Posted August 23, 2018 Report Share Posted August 23, 2018 Will it go if you bump start it down the hill when hot? Quote Link to comment Share on other sites More sharing options...
tshock250 Posted August 23, 2018 Report Share Posted August 23, 2018 I'd start with the carb, check float height & full clean. Quote Link to comment Share on other sites More sharing options...
mcman56 Posted August 23, 2018 Report Share Posted August 23, 2018 Have you tried starting with the throttle fully open? Quote Link to comment Share on other sites More sharing options...
stu109 Posted August 23, 2018 Report Share Posted August 23, 2018 I found my Sherco difficult to start because it was running a bit lean. Give the carb a clean with particular reference to the pilot circuit. Make sure the mixture screw is set OK and see if this helps. Can also run lean if the crank seal on the flywheel side is leaking. If you take the flywheel cover off there should be no up and down movement on the crank. If there is the bearings are shot and the seal will leak. If the bearings are OK it is possible to replace the seal without splitting the engine. I would try the carb first though. Quote Link to comment Share on other sites More sharing options...
v1nn1e Posted August 23, 2018 Report Share Posted August 23, 2018 Once it's started, does it run OK? Are you able to set the idle speed OK and does it idle reliably once warm? Quote Link to comment Share on other sites More sharing options...
misterroy Posted August 24, 2018 Author Report Share Posted August 24, 2018 Once started it is good. Idles OK Crank seal new. Bearings new. Havent tried with the throttle fully open, tried with choke, which is usually how it gets going. I have only tried bump starting it once, the ground was dry enough, it went. Others in the crew can kick it, they have a more powerful kick than me. Cleaning the carb would that mean the fuel is not getting through? If the floats were wrong what would that do? Gonna adjust the carb screws. Quote Link to comment Share on other sites More sharing options...
2stroke4stroke Posted August 24, 2018 Report Share Posted August 24, 2018 Fetch it along to Kidlaw on Sunday and we can have a look. Quote Link to comment Share on other sites More sharing options...
tshock250 Posted August 24, 2018 Report Share Posted August 24, 2018 If other people can kick it no problem, that suggests its not the bike that needs adjusting. Quote Link to comment Share on other sites More sharing options...
b40rt Posted August 24, 2018 Report Share Posted August 24, 2018 On 8/24/2018 at 8:02 AM, tshock250 said: If other people can kick it no problem, that suggests its not the bike that needs adjusting. Expand When are you test riding the "rack" Quote Link to comment Share on other sites More sharing options...
nigel dabster Posted August 25, 2018 Report Share Posted August 25, 2018 the dellorto is a great carb so on an 03 it should be fine. Strip it and make sure the banjo is clean and floats are set at 18.5 Quote Link to comment Share on other sites More sharing options...
misterroy Posted August 25, 2018 Author Report Share Posted August 25, 2018 Adjusted the fuel screw, and today I can mostly kick it. Last night went up a hill no problem in that i did not stall, today the flipping clutch was sticking so there were a few stalls caused by having to react to the clutch. Managed to start without any help from the crew today 1 Quote Link to comment Share on other sites More sharing options...
nigel dabster Posted August 26, 2018 Report Share Posted August 26, 2018 change the oil if its sticking. they used to do this when left for a couple of weeks. Quote Link to comment Share on other sites More sharing options...
pauls320 Posted August 26, 2018 Report Share Posted August 26, 2018 You mentioned that you are having trouble kick starting due to strength issues....Possibly buy a Sherco 3.2 lever which is a little longer and install, will give you a little more leverage?? Just a thought? Quote Link to comment Share on other sites More sharing options...
misterroy Posted August 26, 2018 Author Report Share Posted August 26, 2018 Good idea Paul, maybe the other way, there is enough weight behingd the leg, maybe a shorter kick start would reduce the distance my leg has to travel, giving a quicker spin. Quote Link to comment Share on other sites More sharing options...
