sukahutan Posted September 1, 2018 Report Share Posted September 1, 2018 Hi All, I have a 2003 Edition that's showing her age and I'm finding it difficult to find parts, plus I live in France, so it's also a question of vocabulary. I'm currently looking for the two o rings that sit inside the exhaust muffler as it is blowing there between the muffler and box. Plus I have a tubeless rear tyre which is new but still leaking air from two of the spokes so want to replace the tape that sits inside but where to find this? Tried all my local shops but nothing and searched on line. Any suggestions please? Quote Link to comment Share on other sites More sharing options...
2stroke4stroke Posted September 1, 2018 Report Share Posted September 1, 2018 I found a suggestion on here to use Heldite on the leaking nipple heads to be very successful. 1 Quote Link to comment Share on other sites More sharing options...
arnoux Posted September 1, 2018 Report Share Posted September 1, 2018 The Gas Gas part number for the exhaust O Rings is C290000 - if you google that part number you will find online suppliers who will ship to you. 1 Quote Link to comment Share on other sites More sharing options...
nigel dabster Posted September 2, 2018 Report Share Posted September 2, 2018 the tape is not a gasser part its the same for all makes that age. The only trouble is getting an old style tape the new ones come with integrated valve and just dont seal easily. if at all. 1 1 Quote Link to comment Share on other sites More sharing options...
suzuki250 Posted September 2, 2018 Report Share Posted September 2, 2018 16 hours ago, sukahutan said: Hi All, I have a 2003 Edition that's showing her age and I'm finding it difficult to find parts, plus I live in France, so it's also a question of vocabulary. I'm currently looking for the two o rings that sit inside the exhaust muffler as it is blowing there between the muffler and box. Plus I have a tubeless rear tyre which is new but still leaking air from two of the spokes so want to replace the tape that sits inside but where to find this? Tried all my local shops but nothing and searched on line. Any suggestions please? O rings from a bearing supplier or ebay 1 Quote Link to comment Share on other sites More sharing options...
nigel dabster Posted September 3, 2018 Report Share Posted September 3, 2018 o rings from gas gas uk, unless you can find size, then get red ones. Quote Link to comment Share on other sites More sharing options...
sukahutan Posted September 3, 2018 Author Report Share Posted September 3, 2018 On 01/09/2018 at 9:11 PM, 2stroke4stroke said: I found a suggestion on here to use Heldite on the leaking nipple heads to be very successful. I see Heldite doesn't come cheap. Do you think any gasket sealant would do? Quote Link to comment Share on other sites More sharing options...
sukahutan Posted September 3, 2018 Author Report Share Posted September 3, 2018 On 02/09/2018 at 9:36 AM, nigel dabster said: the tape is not a gasser part its the same for all makes that age. The only trouble is getting an old style tape the new ones come with integrated valve and just dont seal easily. if at all. Is the rim tape the same for tubeless and tubed wheels, or is one sticky? Quote Link to comment Share on other sites More sharing options...
oni nou Posted September 3, 2018 Report Share Posted September 3, 2018 2 hours ago, sukahutan said: Is the rim tape the same for tubeless and tubed wheels, or is one sticky? The tubeless rear rim tape is an air seal and it is not sticky as in it has no adhesive on it..............................the front rim tape is a protector to stop the inner tube being punctured by the spokes/nipples. 1 Quote Link to comment Share on other sites More sharing options...
oni nou Posted September 3, 2018 Report Share Posted September 3, 2018 https://youtu.be/k290LeBasws Clic this 1 Quote Link to comment Share on other sites More sharing options...
miner Posted September 3, 2018 Report Share Posted September 3, 2018 (edited) On 02/09/2018 at 11:36 AM, nigel dabster said: the tape is not a gasser part its the same for all makes that age. The only trouble is getting an old style tape the new ones come with integrated valve and just dont seal easily. if at all. I suffered from this.... GG UK also ship to me in Abu Dhabi... France should be ok too.... Edited September 3, 2018 by miner 1 Quote Link to comment Share on other sites More sharing options...
2stroke4stroke Posted September 3, 2018 Report Share Posted September 3, 2018 (edited) 6 hours ago, sukahutan said: I see Heldite doesn't come cheap. Do you think any gasket sealant would do? No it wouldn't, I have had a 125 ml tin of Heldite for years and used it on various things (bikes, plumbing projects, kicking the tin over) and there is still plenty left. If you think 11 quid (it may be much dearer in France of course) is too much to sort your problem then you're maybe in the wrong sport (and I'm a typical tight trials rider, disinclined to unnecessary expenditure). Lidl and Aldi do boxes of O rings from time to time at little cost (probably less than a pair of genuine ones). Edited September 3, 2018 by 2stroke4stroke 1 Quote Link to comment Share on other sites More sharing options...
nigel dabster Posted September 4, 2018 Report Share Posted September 4, 2018 14 hours ago, oni nou said: https://youtu.be/k290LeBasws Clic this he really skips the actual mechanics of getting the tape into the groove which is much much harder than he intimates, and i most have great difficulty getting it sealed whereas the old style, which is a completely different compound i could do every time relatively easily. 1 Quote Link to comment Share on other sites More sharing options...
oni nou Posted September 4, 2018 Report Share Posted September 4, 2018 (edited) 4 hours ago, nigel dabster said: he really skips the actual mechanics of getting the tape into the groove which is much much harder than he intimates, and i most have great difficulty getting it sealed whereas the old style, which is a completely different compound i could do every time relatively easily. No idea why you find it a struggle; it must be how you are doing it...it's easy to get one of the new type seals in to position and get a good air tight seal if you apply plenty of lubricant on the rim and the rim seal itself then go round the edges with a large flat blade screwdriver[ that has had the sharp edges knocked off with a grinder] and push the edges of the sealing band down under the lips of the well where the band sits. Work in a warm room and warm up the band in some hot water before fitting to make it more pliable. To obtain a good seal;the most important thing is to have the rim perfectly clean of all corrosion in the well where the sealing band sits. Edited September 4, 2018 by oni nou Quote Link to comment Share on other sites More sharing options...
nigel dabster Posted September 5, 2018 Report Share Posted September 5, 2018 On 04/09/2018 at 11:41 AM, oni nou said: No idea why you find it a struggle; it must be how you are doing it...it's easy to get one of the new type seals in to position and get a good air tight seal if you apply plenty of lubricant on the rim and the rim seal itself then go round the edges with a large flat blade screwdriver[ that has had the sharp edges knocked off with a grinder] and push the edges of the sealing band down under the lips of the well where the band sits. Work in a warm room and warm up the band in some hot water before fitting to make it more pliable. To obtain a good seal;the most important thing is to have the rim perfectly clean of all corrosion in the well where the sealing band sits. Boll@cks. I've been doing rim bands since 03. I will give you mine to do if it's that easy, I've done 3 on new rims recently, and SOMETHING isn't as it should be, nothing to do with my technique. How many have you done on which bikes recently? Quote Link to comment Share on other sites More sharing options...
