endurofinn Posted September 3, 2018 Report Share Posted September 3, 2018 Hi! I have a ´17 Scorpa SC 300 factory. Recently, a rattling sound appeared while stationary, and it goes away once I release the clutch enough that the real wheel starts to pull. It's definitely coming from the clutch/tranny area, any ideas? Is the basket worn out so the plates rattle just a bit and create that noise? Quote Link to comment Share on other sites More sharing options...
section swept Posted September 3, 2018 Report Share Posted September 3, 2018 Could be that you just need to refresh the oil, make sure it has the correct type too! Clutches will produce noise especially if the engine idle speed is too slow, causes the clutch to shake and rattle. Worn plates, that is the tags on the plates will invariably create noise and could affect operation. This could also be the gearbox rattling again if the idle is too slow. Quote Link to comment Share on other sites More sharing options...
copemech Posted September 4, 2018 Report Share Posted September 4, 2018 some rattle is just normal with no load on things Quote Link to comment Share on other sites More sharing options...
worldtrialchamp Posted October 29, 2018 Report Share Posted October 29, 2018 2017 model, new generation clutch, perfectly normal... Some a bit more rattly than others... Quote Link to comment Share on other sites More sharing options...
