KompeMax Posted September 7, 2018 Report Share Posted September 7, 2018 I'm using IPONE Soft fork oil maybe a tooo soft because im tooo fatie Which one recommend for trial? Quote Link to comment Share on other sites More sharing options...
oni nou Posted September 7, 2018 Report Share Posted September 7, 2018 (edited) 7 hours ago, KompeMax said: I'm using IPONE Soft fork oil maybe a tooo soft because im tooo fatie Which one recommend for trial? Any make [it does not really matter which one] of fork oil that is SAE 5W viscosity [Standard factory recommendation]........or whatever viscosity your personal preference is depending what the temperature is where you are riding and in which season you are riding. IPONE oils were recommended for use in Sherco trials motorcycles around 2005 ish so you're using a trial oil/fluid Edited September 7, 2018 by oni nou Quote Link to comment Share on other sites More sharing options...
KompeMax Posted September 7, 2018 Author Report Share Posted September 7, 2018 1 hour ago, oni nou said: Any make [it does not really matter which one] of fork oil that is SAE 5W viscosity [Standard factory recommendation]........or whatever viscosity your personal preference is depending what the temperature is where you are riding and in which season you are riding. IPONE oils were recommended for use in Sherco trials motorcycles around 2005 ish so your using a trial oil/fluid Well, Riding in South Norway Its cold always But Maybe go whit for IPONE Grade 10? Soft and hard? for forest? Quote Link to comment Share on other sites More sharing options...
oni nou Posted September 7, 2018 Report Share Posted September 7, 2018 (edited) 4 minutes ago, KompeMax said: Well, Riding in South Norway Its cold always But Maybe go whit for IPONE Grade 10? Soft and hard? for forest? You may find 7.5w will provide enough damping for you if you are in a cold climate. Edited September 7, 2018 by oni nou Quote Link to comment Share on other sites More sharing options...
KompeMax Posted September 7, 2018 Author Report Share Posted September 7, 2018 3 minutes ago, oni nou said: You may find 7.5w will provide enough damping for you if you are in a cold climate. Okay Thanks Quote Link to comment Share on other sites More sharing options...
