b40rt Posted February 11, 2019 Report Share Posted February 11, 2019 If your seriously interested in these bikes the following book is probably the best http://www.ratiopublishing.co.uk Quote Link to comment Share on other sites More sharing options...
evo boy Posted February 11, 2019 Author Report Share Posted February 11, 2019 On 2/10/2019 at 8:08 AM, b40rt said: For the purposes of getting it started any petrol will do, for longer term running and piece of mind castrol do an octane boost / lead replacement . https://www.ebay.co.uk/itm/CASTROL-VALVEMASTER-LEAD-REPLACEMENT-PETROL-ADDITIVE-OCTANE-BOOST-DA6267/323238330293?ul_ref=http://rover.ebay.com/rover/1/710-53481-19255-0/1?ff3=2andpub=5575376664andtoolid=10001andcampid=5338268676andcustomid=9b232b89-2caa-430a-b189-660203316fd0andlgeo=1anditem=323238330293andsrcrot=710-53481-19255-0andrvr_id=1852669596561andrvr_ts=d672addd1680aad98dc1ebdcfff315a8andul_noapp=trueandpageci=cae57e3d-7ab6-4a3f-a927-e9aa0c38acb2andredirect=mobile Thanks for that b40rt I'll get some of that. Would you recommend normal unleaded or super unleaded Quote Link to comment Share on other sites More sharing options...
evo boy Posted February 11, 2019 Author Report Share Posted February 11, 2019 7 hours ago, b40rt said: Points all set up and now have a spark drained tank and filled with fresh fuel kicked and Kicked still no go. Spark plug seems to be getting wet so back to the drawing board ? Quote Link to comment Share on other sites More sharing options...
b40rt Posted February 11, 2019 Report Share Posted February 11, 2019 Normal unleaded is fine. Have you tried a new plug ? When you tickling it, don't go crazy, slightly flood it only. If the plugs wet, dry it, heat it and try again. To start it ease it over compression on the firing stroke, then give it a long push, rather than a kick. 1 Quote Link to comment Share on other sites More sharing options...
section swept Posted February 11, 2019 Report Share Posted February 11, 2019 Timing check would be a good idea! Quote Link to comment Share on other sites More sharing options...
evo boy Posted February 12, 2019 Author Report Share Posted February 12, 2019 10 hours ago, b40rt said: Normal unleaded is fine. Have you tried a new plug ? When you tickling it, don't go crazy, slightly flood it only. If the plugs wet, dry it, heat it and try again. To start it ease it over compression on the firing stroke, then give it a long push, rather than a kick. I'm going to get a new spark plug today it has a NGK B8ES in it is that right? Many thanks Quote Link to comment Share on other sites More sharing options...
b40rt Posted February 12, 2019 Report Share Posted February 12, 2019 NGK BP5ES Quote Link to comment Share on other sites More sharing options...
evo boy Posted February 12, 2019 Author Report Share Posted February 12, 2019 46 minutes ago, b40rt said: NGK BP5ES Thanks for that I'll get one ordered now ? Quote Link to comment Share on other sites More sharing options...
evo boy Posted February 12, 2019 Author Report Share Posted February 12, 2019 New plug fitted and after 20 minutes of kick it fired into life engine sounded sweat. It doesn't want to idle tho which one on the carb is the adjuster screw? PS thanks for all the help you lads gave me so different you my modern bike. Quote Link to comment Share on other sites More sharing options...
b40rt Posted February 12, 2019 Report Share Posted February 12, 2019 Assuming its an amal ? Screw nearest engine is the mixture screw, in for richer. This screw is very sensitive, so make very small adjustments at a time, and only once engine is warm. Screw behind it is tickover, in faster. Quote Link to comment Share on other sites More sharing options...
