Rebound cartridge in Brake caliper fork leg (ok?)
mbeers6
Wasn't paying attention and when reassembling, I put the rebound cartridge in the compression fork leg (i.e. the side with the brake caliper). Will this matter? I don't think it will since each fork will still do its job of compression and rebound. This is the 40mm aluminum Marzocchi forks (2010 250 Pro).
I just put in new fork seals, bled the rebound cartridge and measured the air gap. I really don't want to take it all apart again just to put the rebound cartridge in the other fork leg.
Thanks in advance!!
