oni nou Posted September 19, 2018 Report Share Posted September 19, 2018 4 hours ago, leosantanalg said: they are galfer G1805 pads and galfer disc. before I had jitsie pads and they put grooves on both sides of the rotor! i replaced rotor and pads last time. That is definitely not the problem then......check the feed hole is fully clear at the bottom of the master cylinder reservoir with the brake piston removed from its cylinder and also check that the hole from the inside of the cylinder has no burrs on it that are protruding into the cylinder that could damage the seal on the piston as it is inserted. 1 Quote Link to comment Share on other sites More sharing options...
elemetal Posted September 19, 2018 Report Share Posted September 19, 2018 Try putting the lever under compression with a zip tie overnight. The continuous pressure forces all of the last bit of air up to the reservoir; braketechs on my Vertigo were giving me some of the issues you mention and this trick worked even though I had bled them relentlessly. Quote Link to comment Share on other sites More sharing options...
oni nou Posted September 19, 2018 Report Share Posted September 19, 2018 That works with the old PJA braks awell 1 Quote Link to comment Share on other sites More sharing options...
lineaway Posted September 19, 2018 Report Share Posted September 19, 2018 So are the brakes even trying to work? Are they squeaking? Or does the lever just come to the bar? Quote Link to comment Share on other sites More sharing options...
trev125 Posted September 20, 2018 Report Share Posted September 20, 2018 I had the same problem with my 2016 rear brake. What worked for me was taking apart the master cylinder completely. Even disconnecting the banjo bolt. Blew out with compressed air. I think something was restricting one of the small holes. Quote Link to comment Share on other sites More sharing options...
leosantanalg Posted September 20, 2018 Author Report Share Posted September 20, 2018 15 hours ago, lineaway said: So are the brakes even trying to work? Are they squeaking? Or does the lever just come to the bar? they do work! it brakes but wont really lock and requires a lot of pressure to do stopies and etc... when you doing small rear wheel hops it just sucks cuz it wont lock the front wheel to make the rear alive. (it seems to have a bit of excessive travel on the lever as well. the lever is away far out just in order to have enough braking to ride (but no locking) Quote Link to comment Share on other sites More sharing options...
lineaway Posted September 20, 2018 Report Share Posted September 20, 2018 So squeeze the brake till firm. Does it stay firm or slowly fades away? ( To the bars.) If it does it is probably the M/C. Quote Link to comment Share on other sites More sharing options...
arbutus Posted September 22, 2018 Report Share Posted September 22, 2018 (edited) The pads aren't installed with the metal backing to the disc, I hope? Edited September 22, 2018 by arbutus spelling korrecshun 1 Quote Link to comment Share on other sites More sharing options...
