What does the wire fastened on the rear brake caliper on a 2005 GasGas TXT 125 Pro do?
thesaint
Earlier today i was looking at a 2005 GasGas TXT 125 Pro and also a 2006 GasGas TXT 250 Pro and i bought bouth bikes since they was looking good and the TXT 125 Pro had a engine overhaul not long ago
The only thing i had to do was to replace the rear brake caliper (a brand new rear brake caliper came with the bikes)
When i changed the rear brake caliper about an hour ago i see this wire that is fastened on the rear brake caliper using 1 screw. What is the purpose of the wire?
Also have i placed it correct? See the red arrow on the picture
What does the wire above the red arrow in theis picture do. 2005 GasGas TXT Pro.jpg
Edited by thesaint
Thanks cascao
That makes sense except there will not be any speedometer as long as i own the bike
The wire was not attached since the old rear brake caliper was broken so i installed the wire when i put on the new rear brake caliper so i wonder if it sits correct?
