Mike Brown Posted October 4, 2018 Report Share Posted October 4, 2018 Hi, I’ve been rebuilding a TY125 for some time and have nearly finished, the problem is that the original carb has some serious internal corrosion and I can’t get the bike to run properly. I’ve found an incomplete TY175 carb on eBay but have no idea what main jet size to use, the 175 has a 240 main in the bottom of the float bowl while the 125 has a 100 in the conventional position. Quote Link to comment Share on other sites More sharing options...
section swept Posted October 4, 2018 Report Share Posted October 4, 2018 (edited) Google search TY 125 carb, there you will find a suitable replacement. Main jet is 100 for ty125 as you state. Any carb will do if correctly matched jet wise and choke size. Tyoffroad have a carb that could replace your worn out item around £85.00 you may need to change the jets though to suit smaller engine. I’m sure other suppliers could match up a carb to fit, the worlds your oyster! Edited October 4, 2018 by section swept Quote Link to comment Share on other sites More sharing options...
