Fantic 309
spinner
  • 3 weeks later...
The 307 and 309 are virtually identical. As has been mentioned the exhaust is different the front forks have different dampers and it has a smaller diameter rear disc although it uses the same calliper so the pads are too big and you get a step at the top of the pads as they wear.
Two other things to watch out for is the rear subframe can get worn through where your boots rub against I put some thick rubber tube over it to protect it and the lightweight swing arm spindle is very delicate!
It was brought out the same year as the first KRoo and shares the same colour scheme.
Love my one had it from new. Still think the engine is better the the KRoo was.
