windlestone Posted December 30, 2005 Report Share Posted December 30, 2005 (edited) Do you still have to remove the flywheel cover and clean/dry out after every wet ride? Are the carb flooding problems cured? Are the electrics sorted? Son is considering buying one it's between a beta and a scorpa and i can see i'll be left doing the maintainance Edited December 30, 2005 by windlestone Quote Link to comment Share on other sites More sharing options...
kinell Posted December 30, 2005 Report Share Posted December 30, 2005 It's only 3 bolts to remove the flywheel cover. Wash the bike, remove the cover and lean the bike over to the right to drain any water inside, start the bike and let it run until hot, kill the engine and spray the flywheel and cover with WD40, refit or leave it off until you next use the bike. Also cut a 'V' shape out of the bottom of the cover so that any water that goes in, comes straight back out again. Don't p*** about sealing the cover on, as it's easier to whip it off after each wash. The leaky carb is still the same, JLI's will cure it for Quote Link to comment Share on other sites More sharing options...
montman Posted December 30, 2005 Report Share Posted December 30, 2005 Buy a Scorpa - no sorting and lower maintenance + Great Bike Quote Link to comment Share on other sites More sharing options...
windlestone Posted December 30, 2005 Author Report Share Posted December 30, 2005 Buy a Scorpa - no sorting and lower maintenance + Great Bike <{POST_SNAPBACK}> seen my mate trying to get the carb off his sy250 looked a nightmare kinell is it the stators that were the electrical problem ? any ideas if they are cured ? thanks for info on covers :hat: Quote Link to comment Share on other sites More sharing options...
stuartc Posted December 30, 2005 Report Share Posted December 30, 2005 Buy a Scorpa - no sorting and lower maintenance + Great Bike <{POST_SNAPBACK}> Nice statement from a user with the name MONTMAN Quote Link to comment Share on other sites More sharing options...
montman Posted December 30, 2005 Report Share Posted December 30, 2005 'Nice statement from a user with the name MONTMAN ' Did not want to go 4-stroke so went for another well engineered bike with a jap engine - and very pleased I did! Quote Link to comment Share on other sites More sharing options...
old skool Posted January 2, 2006 Report Share Posted January 2, 2006 ive got one and so far no problems! touch wood i know TW trialssports can sort thr carb problem but mine hasnt leaked yet so havnt sent it off get a beta you know you wanna! Quote Link to comment Share on other sites More sharing options...
