nokesy Posted January 25, 2004 Report Share Posted January 25, 2004 I don't use my bike ('89 TY 250R) as often as I'd like to, and it may not be used for up to 2 months at a time. Is it ok to leave the fuel in the tank for this long? Does 2 stroke mix 'go off', so to speak? and I've usually got 1/2 gallon of 2 stroke mix in a fuel can stored. Is this ok? Thanks for any advice. Quote Link to comment Share on other sites More sharing options...
timp Posted January 25, 2004 Report Share Posted January 25, 2004 When I had a Yam tyz 250 the manual said you should do your 2 stroke mix and use straight away. The oil does separate from the fuel. I have often thought a cause of main bearing failure in some bikes could be due to the oil separating. If you fuel is stood in the bike for a few weeks I would think it possible for a very rich mix to go through the engine first then the rest of the fuel could possibly just be petrol with very little oil. mark t Quote Link to comment Share on other sites More sharing options...
charliechitlins Posted January 25, 2004 Report Share Posted January 25, 2004 I always grab the front brake and pump the forks a few times. Shakes up what's in the tank. I don't know if it helps, but it makes me feel better. Smell your gas. You can tell if it "goes off". The guys I know who use race gas always put it in a metal container so it will last longer. Quote Link to comment Share on other sites More sharing options...
scotty Posted November 9, 2006 Report Share Posted November 9, 2006 not sure about that! i read that once 2-stroke oil (modern) been mixed properly it never seperates again! i think this was a throw back to the 60's when the old 2-stroke oils used to seperate im sure this NOT the case anymore! Quote Link to comment Share on other sites More sharing options...
