steve+cub Posted January 20, 2006 Author Report Share Posted January 20, 2006 Carb arrived yesterday, fitted it and the motor strted first kick, seemed ok apart from a flat spot/hesitancy just off tickover when you snap the throttle open. checked the timing, fine 2-3 hours of fiddling up a notch down a notch and its still the same, so I phoned Surrey Cycles explained the problem. They diagnosed that i need to change the slide up one size to a size 3, it arrived in the post today so I hope to fit it tonight. Spec as delivered 22mm carb no 2 slide 106 needle jet needle on centre groove Apart from the flat spot the motor seems tu pull much better through the range flat spot is most apparent when you crack the throttle open from idle. Quote Link to comment Share on other sites More sharing options...
vinnied Posted January 23, 2006 Report Share Posted January 23, 2006 Steve,I run a 16t gearbox and 58t rear wheel. <{POST_SNAPBACK}> Gearbox 10TL 520 Rear Sprocket TR 242 44 Primary front 16 Vinnie Quote Link to comment Share on other sites More sharing options...
