monty-python Posted January 26, 2004 Report Share Posted January 26, 2004 Does anyone out there have any idea how i could smooth out the low down power of my trusty mont. It's a 99 with a 2002 carb on it (cos the 99 carb was a bit of a joke). At the moment the carb is as it came out of the box, and the bike runs a lot better than it did with the old carb. I had a shot of a 2003 model and it was sooo much smoother, power delivery wise than mine. I don't expect miracles, but i was wondering if i could do anything with what i've got, carb wise to improve matters (other than buy a 2003). . Any ideas anyone?? Quote Link to comment Share on other sites More sharing options...
subira Posted January 26, 2004 Report Share Posted January 26, 2004 You need to speak to Vince at Haven Trialsport. He can port your barrell/cylinder to '03 Plus' spec. I had mine done (02 bike) earlier this year and I really noticed the difference. Its very very smooth, responsive and is much easier to ride. Its about Quote Link to comment Share on other sites More sharing options...
brewster Posted January 26, 2004 Report Share Posted January 26, 2004 I have a 2002 Monty, my first trials bike. I recently changed the reeds to Boyesens for the same reason, to smooth out the low end. They helped quite a bit. Ride on Brewster Quote Link to comment Share on other sites More sharing options...
subira Posted January 26, 2004 Report Share Posted January 26, 2004 Forgot to mention that it runs the std jets 110 main, 33 pilot. Quote Link to comment Share on other sites More sharing options...
trialsurfer Posted January 26, 2004 Report Share Posted January 26, 2004 At Sealevel we run a 35 pilot, smoothes out the idle to midrange transition. Quote Link to comment Share on other sites More sharing options...
sam Posted January 27, 2004 Report Share Posted January 27, 2004 Trialsurfer, Do you guys add any more filter protection, or tape off your vent holes on the seat? The Monty air cleaner system seems so tight the way it is, I'm confused with the other post on this subject. Quote Link to comment Share on other sites More sharing options...
monty-python Posted January 27, 2004 Author Report Share Posted January 27, 2004 Thanks for the tips guys, i shall send haven my barrel when there is a window in the trials calander . I forgot to mention, my bike also occasionally makes a knock sound when i am riding between sections, this happens usually in the first three gears, when it has been revved quite high (not screaming or anything) and then when i shut the throttle - it knocks, usually just the once. |I seem to remember someone saying that this was down to the shape of the combustion chamber and was nothing to worry about. Is this right?? Brewster- How much were the boyesons?? Trialsurfer , i'll try the 35 pilot, would this also help the starting? It usually takes two or three kicks, even when warm? On the subject of the vent holes, i've never had excess mud in my airbox (vents open), was at a muddy trial a few weeks age (it was snowing and finished early). The bike was caked but the filter was no worse than usual, if you're worried just gaffa tape the gap at the rear mudguard/ airbox. Quote Link to comment Share on other sites More sharing options...
trialsurfer Posted January 27, 2004 Report Share Posted January 27, 2004 The larger pilot helps some on the rev-down and throughout the entire range also we run a 50-50 mix of 110 octane with 93 and Silkolene oil. If you service the airfilter you shouldn't have a problem unless you go swimming on the bike! Quote Link to comment Share on other sites More sharing options...
brewster Posted January 27, 2004 Report Share Posted January 27, 2004 I paid $16.00 plus tax and shipping directly from Boyesen. They are in the USA and so am I. The part number for 1999-2002 Monty is #758. Here's their web site; http://shop.boyesen.com/ Ride on Brewster Quote Link to comment Share on other sites More sharing options...
subira Posted January 27, 2004 Report Share Posted January 27, 2004 The Boyesen's can be found at a local MX/Boyesen dealer (I think that they are distributed by AXO/Oakley - not sure though) you'll need to special order them. Other things to consider, black throttle tube, 42 rear sprocket, both slow things a bit and take the edge of the bottom. On the vents, here's my rear guard with the P.38 mesh Quote Link to comment Share on other sites More sharing options...
subira Posted January 27, 2004 Report Share Posted January 27, 2004 (edited) And from the back - not quite as neat but works ! Edited January 27, 2004 by Subira Quote Link to comment Share on other sites More sharing options...
mark christopher Posted January 27, 2004 Report Share Posted January 27, 2004 this is how i do mine the foam is fish pond filter foam. to make it better i am going to make it into a square to go across the front. also make sure you have the black foam seal you can see inside the rear fender! Quote Link to comment Share on other sites More sharing options...
monty-python Posted January 28, 2004 Author Report Share Posted January 28, 2004 Any ideas about the engine knock guys, does anyone elses do this?? Quote Link to comment Share on other sites More sharing options...
