kwackerzak Posted October 27, 2018 Report Share Posted October 27, 2018 This is how the front pipe is fixed to the barrel on my trs. The gap seemed a bit bigger when I got it but I’ve nipped it up a tad. Surely this can’t be right? Quote Link to comment Share on other sites More sharing options...
lineaway Posted October 27, 2018 Report Share Posted October 27, 2018 Have you ever dropped the bike? Exhausts move all the time on all bikes. Unless they just sit in the garage. No oil, no problem. Quote Link to comment Share on other sites More sharing options...
kwackerzak Posted October 27, 2018 Author Report Share Posted October 27, 2018 No, only ridden it lightly twice, with no falls as of yet Quote Link to comment Share on other sites More sharing options...
lineaway Posted October 27, 2018 Report Share Posted October 27, 2018 It is fine, I just looked at my son`s bike,and it is similar. The photo magnified makes it appear worst than it is. The pipe is in all the way and no leaks. Go ride it! Quote Link to comment Share on other sites More sharing options...
heffergm Posted October 27, 2018 Report Share Posted October 27, 2018 They're all like that to some degree. The GG uses a pretty big flange so it's not so pronounced. The Vertigo uses a paper thin one so it's easy to deform (and to over torque the flange bolts). Quote Link to comment Share on other sites More sharing options...
pauls320 Posted October 27, 2018 Report Share Posted October 27, 2018 When installing the header pipe, its best to try make sure the inlet is mated flush with the cylinder before snugging up the flange bolts evenly. Its not uncommon for someone to shove header on ,tighten up one bolt and then try catch up the second one, which does not help the situation. If your worried about it you can carefully bend the flange back with an adjustable wrench next time its off. Now go ride Quote Link to comment Share on other sites More sharing options...
pjw123 Posted October 27, 2018 Report Share Posted October 27, 2018 looks like quite a nice flange anyway Quote Link to comment Share on other sites More sharing options...
section swept Posted October 27, 2018 Report Share Posted October 27, 2018 On 10/27/2018 at 3:06 PM, kwackerzak said: This is how the front pipe is fixed to the barrel on my trs. The gap seemed a bit bigger when I got it but I’ve nipped it up a tad. Surely this can’t be right? Expand Looks like the flange is closer at the front than further back. I’d slacken the front bolt a few threads and pull the rear bolt in by the same amount. You may even find that a flat washer between the spring washer and flange may spread the load a little more and improve the fit. However it looks as though the majority reckon it’s ok that’s as long as it doesn’t leak. Quote Link to comment Share on other sites More sharing options...
