Engine swap?
nicbrrghs
Pretty sure the position of the motor mounting bolts and swing arm pivot points are the same but the head support bracket may need to be customized as 125 and 270 barrels may be different height. Other than that , as cope mentioned there my be other issues...coolant hose routing , etc, 2011 was new style h20 pump if remember correctly...post some pics etc of your build for us:banana:
