tacomann Posted November 5, 2018 Report Share Posted November 5, 2018 Hi folks I've just joined the forum because I've started restoring a 199 Sherpa. The current steering stops are a couple of old bolts welded onto the frame. I'd like to replace these - could someone tell me if the stops are meant to meet against the fork stanchions or the bottom yolk and is it possible for someone to measure the length of the stops on their bike? I suppose I just need to keep some clearance between the petrol tank and the forks on full lock. Quote Link to comment Share on other sites More sharing options...
section swept Posted November 5, 2018 Report Share Posted November 5, 2018 53 minutes ago, tacomann said: Hi folks I've just joined the forum because I've started restoring a 199 Sherpa. The current steering stops are a couple of old bolts welded onto the frame. I'd like to replace these - could someone tell me if the stops are meant to meet against the fork stanchions or the bottom yolk and is it possible for someone to measure the length of the stops on their bike? I suppose I just need to keep some clearance between the petrol tank and the forks on full lock. That’s exactly it, the bolts have probably been welded onto the site of the original lock stops. Some owners remove the lock stops to give increased steering but also have to address tank fouling. The correct lock stops should have nylon caps fitted, these are an interference fit. Order up some replacements £2-3.00 approx and size the lock stop bar accordingly. Quote Link to comment Share on other sites More sharing options...
twinnshock Posted November 5, 2018 Report Share Posted November 5, 2018 (edited) When I bought my brand new M198 cut a bit off thesse stops to get a bit more lock was the very first mod I did, cut back so that the yokes on full lock was just clear of the tank. They are not old bolts welded on but a length of round rod as section swept has confirmed nylon end caps. I have bever bought these having simply made my own again sized to give as much lock as possible. Stuart Edited November 6, 2018 by twinnshock 1 Quote Link to comment Share on other sites More sharing options...
sherpa325 Posted November 6, 2018 Report Share Posted November 6, 2018 Hi they are about 50mm long and 8mm dia. They bottom out on the middle of the fork tube just above the bottom triple clamp. Cheers Greg 2 Quote Link to comment Share on other sites More sharing options...
nigel dabster Posted November 6, 2018 Report Share Posted November 6, 2018 As above, adjust the rods so that you just hit the tank on the stops, then fit the plastic caps. good system works well. you can fine tune stops a little more if you want. 1 Quote Link to comment Share on other sites More sharing options...
tacomann Posted November 6, 2018 Author Report Share Posted November 6, 2018 Thanks for your replies everybody - that all makes sense now and I should be able to tackle the job this weekend. Cheers Quote Link to comment Share on other sites More sharing options...
