mbeers6 Posted November 12, 2018 Report Share Posted November 12, 2018 (edited) Seeking advice from others with newer Pro's using Keihin carb. Photo below is from my 2017 TXT 250 and it seems like the airbox inlet tube is not sealing far enough over the carb. Can anyone with a similar setup let me know if they have the same issue? Please confirm there is NO bushing like there is with the Delorto carb. I looked at microfische and saw nothing like that for the Keihin setup. I looked at the owners manual and it shows the inlet tube all the way over the carb. Not sure how I can get mine further forward besides maybe heating the rubber up and pulling it further forward? Yes I am using a different hose clamp in the pic, but it is the same or worse with the stock airboot clamp. The second photo shows some dirt I found on the slide; I'm very good about cleaning/oiling air filter and using grease around seal. So I'm thinking dirt maybe be getting in between carb and airbox. Thank you in advance. Edited November 12, 2018 by mbeers6 2nd pic Quote Link to comment Share on other sites More sharing options...
sirdabalot Posted November 12, 2018 Report Share Posted November 12, 2018 (edited) You're right there's no bushing. Edited November 12, 2018 by sirdabalot Quote Link to comment Share on other sites More sharing options...
heffergm Posted November 12, 2018 Report Share Posted November 12, 2018 That hose clamp isn't doing you any favors. It's bunching up the boot, which is going to kill any seal, and it's also got perforations which are going to cut into the boot. Clean the carb, inspect boot for damage, use the stock clamp, clean air filter, grease the filter sealing surface lightly with silicone grease, check for air leaks around the boot with WD-40. 1 Quote Link to comment Share on other sites More sharing options...
lineaway Posted November 12, 2018 Report Share Posted November 12, 2018 Pull the carb from the reed cage. Leave the seat bolts out and install inlet from air box. Push seat and carb back into reed boot and tighten. You can actually pry the carb to stretch the rubbers to fit. Install seat bolts. 1 Quote Link to comment Share on other sites More sharing options...
mbeers6 Posted November 12, 2018 Author Report Share Posted November 12, 2018 Thanks Gents, will go back to the stock clamp and give Lineaway's method a shot and report back Quote Link to comment Share on other sites More sharing options...
d2w Posted November 12, 2018 Report Share Posted November 12, 2018 I'm having similar issues with the boots on my older GG's. Thumbs-up to Lineaway's suggestion. In addition I may try to somehow soften the rubber; I was thinking of leaving it near a source of moderate heat (possibly steam from a boiling kettle, or a hairdryer). An open flame or too high a heat or a concentrated heat could be bad.Good luck. Quote Link to comment Share on other sites More sharing options...
paulmac Posted November 13, 2018 Report Share Posted November 13, 2018 Hairdryers work to make rubber a bit more pliable - steam not so good, water and carbies don't really get on very well. Quote Link to comment Share on other sites More sharing options...
zippy Posted November 13, 2018 Report Share Posted November 13, 2018 16 hours ago, d2w said: I'm having similar issues with the boots on my older GG's. Thumbs-up to Lineaway's suggestion. In addition I may try to somehow soften the rubber; I was thinking of leaving it near a source of moderate heat (possibly steam from a boiling kettle, or a hairdryer). An open flame or too high a heat or a concentrated heat could be bad.Good luck. I have used a heat gun on low (doesn't take very long) to soften the rubber boot for my GasGas. My 2003 originally had the Dellorto with the rubber adapter and the rubber boot was a bit deformed, I have a Kehin now and that rubber boot occasionally likes to go back to the deformed shape instead of round. A little warm up and viola good to go. Quote Link to comment Share on other sites More sharing options...
huski Posted November 14, 2018 Report Share Posted November 14, 2018 Are you sure the boot is on the carb properly?Sometimes it doesn't go on fully on the side you can't easily see(the shock side) leaving a gap 1 Quote Link to comment Share on other sites More sharing options...
mbeers6 Posted November 14, 2018 Author Report Share Posted November 14, 2018 Tried Lineway's method and it definitely helped. The other issue I found is that the plastic frame guards I have seemed to have been preventing the airbox itself from fully seating against frame. Took those off and was able to get the airbox inlet tube little further onto the carb bell housing. Thanks for all the help guys. 1 Quote Link to comment Share on other sites More sharing options...
