sando994 Posted November 17, 2018 Report Share Posted November 17, 2018 I have a 2015 4rt standard. Ive been offered some Showa forks from a repsol model. Does anyone know if I fit the forks, is the front spindle the same for the tech and Showa forks? Quote Link to comment Share on other sites More sharing options...
jimmyl Posted November 17, 2018 Report Share Posted November 17, 2018 (edited) You can check parts lists on line to see if different.. i recall the showa set up had a spacer on the disc side which is not needed on the tech forks as the bottom boss is wider . Would maybe suggest thread is a different length?? Edited November 17, 2018 by jimmyl Quote Link to comment Share on other sites More sharing options...
jimmyl Posted November 17, 2018 Report Share Posted November 17, 2018 Just checked - different part numbers Quote Link to comment Share on other sites More sharing options...
sando994 Posted November 18, 2018 Author Report Share Posted November 18, 2018 Thanks jimmyl, I’ll have to get the Showa spindle and Speedo drive then. Quote Link to comment Share on other sites More sharing options...
