midlife Posted November 19, 2018 Report Share Posted November 19, 2018 Anyone out there using the blue coil on their 240 is the wiring from the front black green red. Quote Link to comment Share on other sites More sharing options...
motosolex Posted December 5, 2018 Report Share Posted December 5, 2018 Here’s what we’ve seen thus far. Subject to confirmation. We hooked ours up accordingly. Still no spark. May need to dig into the stators. Any tips on flywheel removal? Quote Link to comment Share on other sites More sharing options...
fourex Posted December 5, 2018 Report Share Posted December 5, 2018 It looks like you have the red and green wires from the stator transposed. Quote Link to comment Share on other sites More sharing options...
motosolex Posted December 5, 2018 Report Share Posted December 5, 2018 Will rewire tomorrow. Thanks for the astute observations. Quote Link to comment Share on other sites More sharing options...
motosolex Posted December 5, 2018 Report Share Posted December 5, 2018 And of course Yellow wire still grounded to frame? Quote Link to comment Share on other sites More sharing options...
fourex Posted December 5, 2018 Report Share Posted December 5, 2018 22 minutes ago, motosolex said: And of course Yellow wire still grounded to frame? Yes, yellow wire with lug on it grounded to frame. Quote Link to comment Share on other sites More sharing options...
motosolex Posted December 6, 2018 Report Share Posted December 6, 2018 Thank you Fourex. Well, swapped around the wires to no avail. Used the Ohm meter to measure wires from magneto on the red wire to frame and green wire to frame. No resistance/ continuity on either. The black wire from the mag did show continuity. Can anyone confirm or indicate correct readings? ————————- We wonder now if there is a wire, pickup or stator issue???? Any Flywheel removal techniques or pointers? Thanks Quote Link to comment Share on other sites More sharing options...
grib Posted December 9, 2018 Report Share Posted December 9, 2018 The hand drawn diagram above is correct for wiring the 240 stator to the later type coil. I would suggest taking the flywheel off and checking the stator, the only way to remove the flywheel is with the correct puller. Quote Link to comment Share on other sites More sharing options...
motosolex Posted December 28, 2018 Report Share Posted December 28, 2018 We have spark! After basically rebuilding the whole stator and re-wireing plus new fasteners and a Ducati Energia CDI....we have a nice spark. Now a few fitment issues and she ought to go. Thanks to all the inputs from all of you! attached a nice flywheel timing picture Quote Link to comment Share on other sites More sharing options...
