Russ Bedford Posted November 19, 2018 Report Share Posted November 19, 2018 Hi all..I'm after some advice regarding my Sherco 2.9 2004. I just can't get her running properly,when I blip the throttle the bike dies..I even struggle to get it to stay running on tick-over.I've fiddled with the mixture and tick-over screws to no avail. Up to yet I've checked the fuel,installed a new inline fuel filter,cleaned and oiled the air filter,had the carb ultra sound cleaned,all the jets cleaned,and checked the carb for leaks with wd40..someone has said it must be the crank seals..I've no idea how to check these so any advice would be much appreciated.!! I'm going to the Ilse of Skye for a week at Xmas and I really want to take the bike with me,so I'm starting to get abit worried ?..Thanks..Russ. Quote Link to comment Share on other sites More sharing options...
b40rt Posted November 19, 2018 Report Share Posted November 19, 2018 Have you tried a new plug ? Some " petrol " problems are actually ignition, just to throw another variable. What were you doing when the problem started ? Quote Link to comment Share on other sites More sharing options...
Russ Bedford Posted November 19, 2018 Author Report Share Posted November 19, 2018 Hi,thanks for the reply.. To be honest the bike had been stood for 3mnth in my hallway..I decided I'd better get it outside and fired up,but a few seconds after turning the fuel on,the carb started leaking fuel,so I assumed the floats were either stuck or had leaked fuel inside..anyway after getting it back together and back on I started with the running problems.The new plug came today so I'll try it tomorrow night..one thing though,at work today it suddenly popped in my head to check the crankcase breather pipe,which was blocked.I don't know if that will make any difference.. Quote Link to comment Share on other sites More sharing options...
b40rt Posted November 19, 2018 Report Share Posted November 19, 2018 Your crankcase may be flooded in that case, this could also affect the plug. Kick it over plug out, fuel off, kill switch pushed. Give it a chance to dry out, then try with new plug. Your carb isn't one that you can put the floats in upside down ? Quote Link to comment Share on other sites More sharing options...
Russ Bedford Posted November 19, 2018 Author Report Share Posted November 19, 2018 No,I double checked I'd put the floats in correctly,pins to the bottom. I'll follow your advice tomorrow night after work..I have to be careful with the bike because there's young kids next door and they go to bed Early.. Quote Link to comment Share on other sites More sharing options...
section swept Posted November 20, 2018 Report Share Posted November 20, 2018 19 hours ago, Russ Bedford said: No,I double checked I'd put the floats in correctly,pins to the bottom. I'll follow your advice tomorrow night after work..I have to be careful with the bike because there's young kids next door and they go to bed Early.. That won’t stop them blasting your ears when they get a bit older and don’t go to bed early? Quote Link to comment Share on other sites More sharing options...
Russ Bedford Posted November 20, 2018 Author Report Share Posted November 20, 2018 I here ya.!! But also I live in a smoke free zone,but i'm burning logs in my stove, so I don't want to upset anyone..you know how fickle some neighbour's can be, and it's not long before someone grasses you up.!! Quote Link to comment Share on other sites More sharing options...
Russ Bedford Posted November 20, 2018 Author Report Share Posted November 20, 2018 I've just took the plug out,so I'm gonna try your advice and then leave it overnight to dry out.. Quote Link to comment Share on other sites More sharing options...
Russ Bedford Posted November 21, 2018 Author Report Share Posted November 21, 2018 Hi,I've tried the bike with a new plug (gap .5mm) and it's no different..about 10 seconds after turning the choke off the bike wants to stall,regardless what you do with the tick-over screw.I have noticed though that when you rev it to keep it going it takes longer than normal for the revs to go down i.e the revs drop slowly.. Quote Link to comment Share on other sites More sharing options...
b40rt Posted November 21, 2018 Report Share Posted November 21, 2018 Carb leaking is cured ? Assume it is as sounds like running lean. You have tried spraying brake cleaner or similar around carb, manifold etc ? Quote Link to comment Share on other sites More sharing options...
Russ Bedford Posted November 21, 2018 Author Report Share Posted November 21, 2018 Yes I've tried wd40 around the carb and inlet manifold,but I think I'll try it again.What are the crank seals like to do,is there an easy way of checking them?How would I get to them as I've had nothing to do with those before.. Quote Link to comment Share on other sites More sharing options...
b40rt Posted November 21, 2018 Report Share Posted November 21, 2018 Something like carb cleaner is better as more volatile. There are crank seals on both sides obviously, but as there is no excessive smoke you need to look at the flywheel side. Remove the cover and spray behind the flywheel onto / around the crankshaft. Quote Link to comment Share on other sites More sharing options...
Russ Bedford Posted November 25, 2018 Author Report Share Posted November 25, 2018 Hi,just to update you..I've removed the flywheel cover and sprayed carb cleaner behind the flywheel as it was struggling to tick over,it seams to be the crank seal because as I sprayed the bike ticked over lovely but as soon as I stopped spraying it struggled and died.. Is the flywheel easy to remove? I assume I'd need a puller of some sort? Quote Link to comment Share on other sites More sharing options...
b40rt Posted November 25, 2018 Report Share Posted November 25, 2018 Check if this is the correct one https://www.splatshop.co.uk/sherco-flywheel-puller.html Quote Link to comment Share on other sites More sharing options...
Russ Bedford Posted November 25, 2018 Author Report Share Posted November 25, 2018 Thanks for that,I'll give them a call tomorrow ? Quote Link to comment Share on other sites More sharing options...
