andrewmorpeth Posted November 29, 2018 Report Share Posted November 29, 2018 (edited) I’ve got an electrical problem with my hidria ignition system on my 2018 gp it will fire then die .No spark I’ve swapped plugs coil and cdi with a friends bike and it makes no difference it’ll run on his but not mine.If you leave it for a while the spark will return but not for long I’ve had all connectors apart and kill switch disconnected and connected?Im thinking stator? Edited November 29, 2018 by andrewmorpeth Spelling Quote Link to comment Share on other sites More sharing options...
cascao Posted November 29, 2018 Report Share Posted November 29, 2018 Check coils. Heat can sometimes change ohms reading on defective coils. Quote Link to comment Share on other sites More sharing options...
andrewmorpeth Posted November 29, 2018 Author Report Share Posted November 29, 2018 You mean the stator coils?If so what readings am I looking for? Quote Link to comment Share on other sites More sharing options...
lineaway Posted November 30, 2018 Report Share Posted November 30, 2018 It is a bad ground. If it will not start, try just taking the spark plug cap off, then re-install. I bet it fires, but not runs. Quote Link to comment Share on other sites More sharing options...
b40rt Posted November 30, 2018 Report Share Posted November 30, 2018 2018 bike, think I'd be speaking to the dealer / importer. 3 Quote Link to comment Share on other sites More sharing options...
NAD1 Posted November 30, 2018 Report Share Posted November 30, 2018 On 11/30/2018 at 8:25 AM, b40rt said: 2018 bike, think I'd be speaking to the dealer / importer. Expand Ha... UK importer hides behind some made up 6 month warranty cr@p despite that breaking EU laws 1 Quote Link to comment Share on other sites More sharing options...
huski Posted November 30, 2018 Report Share Posted November 30, 2018 Can you try the stator from another bike? Quote Link to comment Share on other sites More sharing options...
lineaway Posted December 1, 2018 Report Share Posted December 1, 2018 My bike (before I owned it) would mysteriously stop running. Not very fun pushing the bike. I suggested removing all the stator bolts, cleaning, greasing and re - install. He also removed and cleaned up all the grounding points. It has never given me a problem since. Seems like a similar problem as it was about the same age and a Hidria ignition. It seems it would lose the ground when warm , almost working and then it would ground it self through the plug. Quote Link to comment Share on other sites More sharing options...
marcusmkspares Posted February 8, 2020 Report Share Posted February 8, 2020 does anybody have a test procedure for 2017 hidria ignition system got no spark Quote Link to comment Share on other sites More sharing options...
