motosolex Posted December 5, 2018 Report Share Posted December 5, 2018 Hi fellows. Fitted the blue Ducati Energia coil as per the attached diagram. Still no spark and now considering removal of flywheel to dig deeper. Any tips on flywheel removal operation (standard r-h threads)? Anything else to consider or look for? Thanks. Quote Link to comment Share on other sites More sharing options...
Fantic.156 Posted December 6, 2018 Report Share Posted December 6, 2018 Geetings, before removing the flywheel etc, I'd check the resistance values from the coils and pick up using a multi meter. I am sure the values are on a thread within Fantic 240 if you take time to look through the previous posts. Cheers Quote Link to comment Share on other sites More sharing options...
motosolex Posted December 6, 2018 Author Report Share Posted December 6, 2018 6 hours ago, Fantic.156 said: Geetings, before removing the flywheel etc, I'd check the resistance values from the coils and pick up using a multi meter. I am sure the values are on a thread within Fantic 240 if you take time to look through the previous posts. Cheers Thanks. Did so. When checking Green to Ground no resistance. Red to Ground no resistance. So problem is in wires, connections or the stator coil if I understand the system. . Cheers Quote Link to comment Share on other sites More sharing options...
Fantic.156 Posted December 6, 2018 Report Share Posted December 6, 2018 Hi, to check the pick up coil, you should get Red= 0.0 ohms, and green=40-50 ohms Quote Link to comment Share on other sites More sharing options...
motosolex Posted December 6, 2018 Author Report Share Posted December 6, 2018 Thank you F.156! and those readings are taken ground to red, ground to green? Just to clarify. Appreciate your help. Quote Link to comment Share on other sites More sharing options...
fantic240motor Posted December 6, 2018 Report Share Posted December 6, 2018 You'll need a 26mm x 1.5 flywheel puller for a 240. I use a homemade holder. If the wires are original there's a good chance the insulation may have broken down causing problems. If the stator has been rewired you'll need to identify what wires are what as the colours may well be different to original. Quote Link to comment Share on other sites More sharing options...
motosolex Posted December 6, 2018 Author Report Share Posted December 6, 2018 Thanks F.240Motor. Yep wires are very brittle. May be the culprit. Do you have a picture of the homemade holder? thank you. Quote Link to comment Share on other sites More sharing options...
fantic240motor Posted December 7, 2018 Report Share Posted December 7, 2018 Here it is motosolex. The two bolts locate in the flywheel holes. The cut out is to clear the kickstart shaft but also doubles to hold everything from moving. Easy to make something similar from a piece of steel plate. Quote Link to comment Share on other sites More sharing options...
motosolex Posted December 9, 2018 Author Report Share Posted December 9, 2018 On 12/7/2018 at 3:07 AM, fantic240motor said: Here it is motosolex. The two bolts locate in the flywheel holes. The cut out is to clear the kickstart shaft but also doubles to hold everything from moving. Easy to make something similar from a piece of steel plate. This is used in lieu of a typical puller? If so, I can’t visualize how it pulls. Quote Link to comment Share on other sites More sharing options...
b40rt Posted December 9, 2018 Report Share Posted December 9, 2018 3 hours ago, motosolex said: This is used in lieu of a typical puller? If so, I can’t visualize how it pulls. It's to stop the flywheel turning while your removing flywheel nut etc. If you have a compressor, an air gun will generally work without a holder. 2 Quote Link to comment Share on other sites More sharing options...
motosolex Posted December 9, 2018 Author Report Share Posted December 9, 2018 6 hours ago, b40rt said: It's to stop the flywheel turning while your removing flywheel nut etc. If you have a compressor, an air gun will generally work without a holder. Brilliant. Thanks. 1 Quote Link to comment Share on other sites More sharing options...
fantic240motor Posted December 9, 2018 Report Share Posted December 9, 2018 Sorry motosolex should have been more clear. As mentioned it's just to hold while undoing and tightening the nut. I've personally never been happy using an impact wrench to tighten flywheel nuts but I know friends that have. Just another point. When you tighten the puller bolt to remove the flywheel be patient. If the flywheel hasn't been off for a long time they can be stubborn. Don't overnighten the bolt if it won't shift. I've had to gently tap a flywheel with a soft mallet while the puller pulls. Another note... pay particular attention to the woodruff key. If it's not very tight in it's slot make sure it doesn't push out when re-fitting the flywheel. Before I fully tighten the nut I like to slowly rotate the engine to make sure the flywheel has pulled up true on the taper. 1 Quote Link to comment Share on other sites More sharing options...
motosolex Posted December 9, 2018 Author Report Share Posted December 9, 2018 Excellent info. Thank you F240Motor. Quote Link to comment Share on other sites More sharing options...
grib Posted December 10, 2018 Report Share Posted December 10, 2018 Another method which works well when removing the flywheel is to tighten the puller bolt and then give the head of the bolt a sharp tap with a copper hammer. Quote Link to comment Share on other sites More sharing options...
section swept Posted December 14, 2018 Report Share Posted December 14, 2018 On 12/9/2018 at 4:50 PM, fantic240motor said: Sorry motosolex should have been more clear. As mentioned it's just to hold while undoing and tightening the nut. I've personally never been happy using an impact wrench to tighten flywheel nuts but I know friends that have. Just another point. When you tighten the puller bolt to remove the flywheel be patient. If the flywheel hasn't been off for a long time they can be stubborn. Don't overnighten the bolt if it won't shift. I've had to gently tap a flywheel with a soft mallet while the puller pulls. Another note... pay particular attention to the woodruff key. If it's not very tight in it's slot make sure it doesn't push out when re-fitting the flywheel. Before I fully tighten the nut I like to slowly rotate the engine to make sure the flywheel has pulled up true on the taper. The airwrench is only for undoing the flywheel nut....its not used to tighten, at least I don’t. Quote Link to comment Share on other sites More sharing options...
