Hour meter
guy53
What do you need to know? It takes about 38 seconds. Just find a good place to mount the meter, trim the wire to length, keeping in mind you need to wrap it around the spark plug/HT lead about 5 or 6 times (see the instructions on the meter). Some electrical tape around the wire finishes the job.
  • Like 2
I've had two (inexpensive) - neither lasted long enough to be of any practical use.
I'm not convinced time alone means much on a trials bike.  i prefer to look back on what events I have done and assess how they may have, for instance, affected the oil.  Two hours putting round a field doing sections is not the same as two hours spent blasting over the moors.
Edited by 2stroke4stroke
True.. but you need to know you've done two hours in the first place.
  • 2 weeks later...
£6.00 Asda look for the cycle accessories display Bell products cycle computer, does speed, distance and a few other techie things and has a memory. Its small, light and comes complete with all fixings. You may need to make a mounting for the sensor a fairly easy thing to do, waterproof too!?
