2014 footpeg hanger snapped Gas Gas Factory
nicbrrghs
I had an 2006 model that both sides broke off. Had them welded back on and no troubles. They were actually already cracked from manufacture because parts of the cracked surfaces were chromed when the frame was done.
Weight and usage, some of these footrest location mountings do look a little lightweight in construction....just my observation. Potentially with bigger footrests fitted (standard manufacturers pegs replaced) there will be a bit more leverage created at the mounting point and subsequent cracking.?
