Changing pads in braktec caliper
betaboy100
Hi all, im trying to change the pads in my braktec caliper on my gasgas racing 2014. The last pad change i did was on an ajp caliper and had the two pins that you undid to slide the pad out. I was wondering if anyone could talk me through this new way as i dont want to damage anything. Thanks in advance:) Liam
Edited by betaboy100
Unbolt  calliper
push piston back most of the way
This will alllow 1 pad to fall forward and out then the 2 nd one is easy
to put back put the one pad in and push into place with a small screw driver and second one will then go back in.
not sure what the benefit over the old design with a pin but they where much easier and I’m sure the friction material was thicker as not restricted by the install method
Edited by jimmyl
