danbillam Posted December 30, 2018 Report Share Posted December 30, 2018 Anyone in here swapped there slide in a beta 300 to give it more zap off the bottom? a good rider I ride with has a gas gas 300 gp and he has altered the slide to give that more grunt off the bottom and it rides amazing so much more low down power from a stand still compared to my beta. So I think I’m going to try this until I can upgrade bikes in a few months. The manual gives all carb settings bar the slide number so if any one knows what’s fitted in 18 evo 300 that would be great before I have to wait and ring beta after the new year. Quote Link to comment Share on other sites More sharing options...
lineaway Posted December 30, 2018 Report Share Posted December 30, 2018 You could fiddle and jet till 2020 and it will never feel like a gasser. The Beta is a slow motor. Now if you put the flywheel on that we get, it will go far better. Quote Link to comment Share on other sites More sharing options...
danbillam Posted December 30, 2018 Author Report Share Posted December 30, 2018 I was just hoping to get a bit more until I can get a new gasser. Which flywheel is that? And I’ve been told there is a weight on the gearbox side like the flywheel weight? Quote Link to comment Share on other sites More sharing options...
lineaway Posted December 30, 2018 Report Share Posted December 30, 2018 G.B. spec bikes have several heavier parts. You can find them in the parts break down. In the USA Beta sells a bike called the SS ie Super Smooth. We call it the super slow. Basically a G.B. spec bike. For 80 % of the riders in the UK, the GB spec bike is appropriate for the wet sections. The style of riding between a Gas Gas and a Beta is quite different. I love how a Gasser rides, but I score better on a Beta. Quote Link to comment Share on other sites More sharing options...
danbillam Posted December 30, 2018 Author Report Share Posted December 30, 2018 I’ll have a look see if I can get the weight on gearbox side out if it’s easy enough. I might ring beta up when they’re open and see what else can be removed I think I’d read somewhere there might be an extra base gasket aswell but not sure about that Quote Link to comment Share on other sites More sharing options...
danbillam Posted December 30, 2018 Author Report Share Posted December 30, 2018 I’ve had a look through the parts diagrams and no weights are mentioned at all not even the flywheel weight so no further with that. For base gaskets it lists the ss as having 2x 0.5mm gaskets and the 300 having 1x1mm gasket so doesn’t look like one of these can be removed either Quote Link to comment Share on other sites More sharing options...
lineaway Posted December 30, 2018 Report Share Posted December 30, 2018 They are not separate weights. They are whole parts that weigh more. The clutch basket and primary gear is one set. Not a removable part. Any of this is not a cheap fix. Quote Link to comment Share on other sites More sharing options...
lineaway Posted December 30, 2018 Report Share Posted December 30, 2018 First gear is also terribly low on the Beta. Using second more can help make up for the motor. Quote Link to comment Share on other sites More sharing options...
danbillam Posted December 30, 2018 Author Report Share Posted December 30, 2018 Looks like I’ll just put up with it for a few months till I can get new bike then. I never use 1st anyway mate just 2nd 3rd and occasionally 4th. Just wanted that bit quicker grunt for big steps from a stand still without ringing it’s neck Quote Link to comment Share on other sites More sharing options...
danbillam Posted January 8, 2019 Author Report Share Posted January 8, 2019 I’ve rang beta today and they confirmed the weight on the clutch side is removeable. You take out the basket and it’s pressed onto the crankshaft and just pulls off. Mare the baskets easy to remove? Quote Link to comment Share on other sites More sharing options...
rcgods Posted January 9, 2019 Report Share Posted January 9, 2019 18 hours ago, danbillam said: I’ve rang beta today and they confirmed the weight on the clutch side is removeable. You take out the basket and it’s pressed onto the crankshaft and just pulls off. Mare the baskets easy to remove? Manual for stripping 2017 onwards motors on the Beta USA Site https://www.betausa.com/sites/default/files/pdf/trialsservicemanuals/2017-2018 Evo 2 stroke engine service manual .pdf Instructions are from page 19 onwards. Only thing you will need apart from sockets etc, is a clutch holding tool maybe a gear puller. Quote Link to comment Share on other sites More sharing options...
Sir Real Ed Posted January 9, 2019 Report Share Posted January 9, 2019 1 hour ago, rcgods said: Manual for stripping 2017 onwards motors on the Beta USA Site https://www.betausa.com/sites/default/files/pdf/trialsservicemanuals/2017-2018 Evo 2 stroke engine service manual .pdf Instructions are from page 19 onwards. Only thing you will need apart from sockets etc, is a clutch holding tool maybe a gear puller. Outstanding manual. Thanks for posting. ? Quote Link to comment Share on other sites More sharing options...
danbillam Posted January 10, 2019 Author Report Share Posted January 10, 2019 Can you see which the weight is from those pictures anyone? Thanks Quote Link to comment Share on other sites More sharing options...
oni nou Posted January 10, 2019 Report Share Posted January 10, 2019 7 hours ago, danbillam said: Can you see which the weight is from those pictures anyone? Thanks The primary gear in the pictures has no weight fitted as it must not be the UK market version of the motor. Quote Link to comment Share on other sites More sharing options...
dan williams Posted January 10, 2019 Report Share Posted January 10, 2019 Carbon fiber reeds will make a world of difference. I like the Moto Tassani reeds. They stopped selling ones specifically for Beta but you can use the housing for a ktm65 and get the medium reeds and the bike will lose no top yet grunt like a freight locomotive. When I get home I’ll look up part numbers. Quote Link to comment Share on other sites More sharing options...
