spomey Posted December 30, 2018 Report Share Posted December 30, 2018 what paths are there for the oil and water to mix? obviously, the water pump seal but are there other seals? I replaced the water seal assembly with all new, it still leaks water into the trans oil, and there is oil in my coolant..like they both can flow both ways I removed the water pump from the case and pressurized the coolant system to about 15 psi. it held air for several hours. any ideas? Quote Link to comment Share on other sites More sharing options...
lineaway Posted December 30, 2018 Report Share Posted December 30, 2018 So you updated to the new water pump? Or you rebuilt yours? Quote Link to comment Share on other sites More sharing options...
arnoux Posted December 31, 2018 Report Share Posted December 31, 2018 Did you replace the shaft as well as the seal? Usually have to do both at the same time. Quote Link to comment Share on other sites More sharing options...
pjw123 Posted December 31, 2018 Report Share Posted December 31, 2018 Arnou is correct. The main reason for oil emulsion, is that the pump shaft develops wear grooves in it over time where the seal makes contact with the shaft. Replacing the seal alone won't solve the problem. If the shaft finish is not perfectly smooth, then 9 times out of 10, you will need to fit a water pump overhaul kit. BTW, Don't forget to use proper marine / water pump grease during re assembly. Quote Link to comment Share on other sites More sharing options...
spomey Posted January 1, 2019 Author Report Share Posted January 1, 2019 correct I replaced everything shaft impeller seal bolt...it turns ou the seal has a split in it. apparently, the spit was able to keep air pressure in the system. I charged the system with air then after a few hours checked it by removing the radiator cap and i would hear the compressed air escaping. ordering a new seal...but again my question is. are there other paths for the coolant/oil to mix? I can't think of any but I haven't ever had this bike apart to see for myself Quote Link to comment Share on other sites More sharing options...
richt Posted January 1, 2019 Report Share Posted January 1, 2019 When you get your new seal apply some engine oil to the shaft and the hole in the seal. This will prevent the seal getting sliced when putting the shaft through it! No other paths for Oil and Coolant to mix, just the water pump. You can get coolant in the oil if the cylinder head seal leaks then the higher pressure builds up in the coolant system and will breach the waterpump seal. Always make sure the radiator breather hose is clear and not kinked so that the pressure can blow out into the open and hopefully not into the oil. Quote Link to comment Share on other sites More sharing options...
spomey Posted January 2, 2019 Author Report Share Posted January 2, 2019 Thanks that's just what I needed to hear. I lubed the seal when I installed it the first time but the failed area was on the outer edge of the rubber away from the shaft. So I think the seal hung up on the shaft and tore the outer edge when the rubber is the thinnest. I think.... Trying again! But it's great to hear there are no other paths. Quote Link to comment Share on other sites More sharing options...
