Mcasp Posted January 2, 2019 Report Share Posted January 2, 2019 Hi all, Wanna change gearbox oil on my '98 315r, found very small filler cap behind clutch hose where it enters engine/clutch housing, but can't seem to find drain bolt???? Taken sump guard off ,,,nothing?? Help!!!!!! Quote Link to comment Share on other sites More sharing options...
barnesy Posted January 2, 2019 Report Share Posted January 2, 2019 If you look under the gear shift lever you will see the drain bolt.. Cheers Quote Link to comment Share on other sites More sharing options...
Mcasp Posted January 2, 2019 Author Report Share Posted January 2, 2019 Nice one Thanks Quote Link to comment Share on other sites More sharing options...
Mcasp Posted January 2, 2019 Author Report Share Posted January 2, 2019 Am I being really dumb can't see it!! Quote Link to comment Share on other sites More sharing options...
jimmyl Posted January 2, 2019 Report Share Posted January 2, 2019 12mm headed bolt going into the side of casing not underneath Quote Link to comment Share on other sites More sharing options...
Mcasp Posted January 2, 2019 Author Report Share Posted January 2, 2019 Ok!!! I'll have a look in the morning !cheers Quote Link to comment Share on other sites More sharing options...
Mcasp Posted January 2, 2019 Author Report Share Posted January 2, 2019 Got it!! Just to be sure 520 ml of oil and the elf one is best for this model?? Quote Link to comment Share on other sites More sharing options...
snowball Posted January 3, 2019 Report Share Posted January 3, 2019 500 gets you 2 changes Quote Link to comment Share on other sites More sharing options...
jimmyl Posted January 3, 2019 Report Share Posted January 3, 2019 22 hours ago, Mcasp said: Got it!! Just to be sure 520 ml of oil and the elf one is best for this model?? Glad your sorted ATF works well in the gearbox also ? Lots of PDF versions of the manual on the web if you google/search TC past forums Quote Link to comment Share on other sites More sharing options...
Mcasp Posted January 3, 2019 Author Report Share Posted January 3, 2019 Cheers snowball! Thanks Jimmy yes I need to get a manual! Quote Link to comment Share on other sites More sharing options...
