Junglejeff Posted January 4, 2019 Report Share Posted January 4, 2019 (edited) I am rebuilding a ty250a.I have only been riding trials since spring of 2018 but figured I would share my rebuild for all to injoy (or laugh at).I ride a 2015 GG txt pro but like vintage bikes.The ty250 was my 1st motorcycle I had in 1976 when my father purchased it for me.The deal was I would work in woods taking down tree's to pay him back.I had no idea it was a trials bike but rode the hell out of it. Edited January 28, 2019 by Junglejeff Wrong date Quote Link to comment Share on other sites More sharing options...
Junglejeff Posted January 4, 2019 Author Report Share Posted January 4, 2019 Engine ran but barely when I got it.Found broken piston and slightly loose rod and right main bearing. I purchased a rod kit from B&J performance and a clutch carrier bearing and a front fender.Picked up a oko 26mm carb for it also.Ordered some falcon 13.4" shocks for it today from Europe.My performance shop informed me today my crank was done and my cylinder is fit to new wossner piston so looking forward to picking that up next week. 1 Quote Link to comment Share on other sites More sharing options...
Junglejeff Posted January 4, 2019 Author Report Share Posted January 4, 2019 The man at the performance shop was real surprised at the quality of the crankshaft.He does not get to work on bike stuff alot as he mainly does snowmobile and marine performance engines. He was amazed at how yamaha built such a nice crank for this application. He was able to true crank to within. 0005" with ease. 1 Quote Link to comment Share on other sites More sharing options...
faussy Posted January 4, 2019 Report Share Posted January 4, 2019 (edited) On 1/4/2019 at 9:22 AM, Junglejeff said: He was able to true crank to within. 0005" with ease. Expand Thats probably because Japanese bikes have relatively loose big end pins in comparison to European manufacturers PS id be careful with your swingarm angle, don't over do it Edited January 4, 2019 by faussy 1 Quote Link to comment Share on other sites More sharing options...
Junglejeff Posted February 14, 2019 Author Report Share Posted February 14, 2019 have most of welding and repairs done.Installed a new rear right motor mount to replace the broken one.frame and swingarm will go to powdercoat shop next week for a coat of yellow. On 1/4/2019 at 12:45 PM, faussy said: Thats probably because Japanese bikes have relatively loose big end pins in comparison to European manufacturers PS id be careful with your swingarm angle, don't over do Expand Quote Link to comment Share on other sites More sharing options...
feetupfun Posted February 14, 2019 Report Share Posted February 14, 2019 (edited) That gusset in front of the rear upright must be pretty close to the rear end of the main chamber of the exhaust Edited February 14, 2019 by feetupfun Quote Link to comment Share on other sites More sharing options...
guy53 Posted February 14, 2019 Report Share Posted February 14, 2019 Also, why put gusset behind the upright ? I did not, and I never had any problem. Guy Quote Link to comment Share on other sites More sharing options...
Junglejeff Posted February 16, 2019 Author Report Share Posted February 16, 2019 On 2/14/2019 at 8:57 AM, feetupfun said: That gusset in front of the rear upright must be pretty close to the rear end of the main chamber of the exhaust Expand About 5 mm away.I bolted on exaust to make sure there was not going to be interference before I put them on. 1 Quote Link to comment Share on other sites More sharing options...
Junglejeff Posted February 16, 2019 Author Report Share Posted February 16, 2019 On 2/14/2019 at 10:53 AM, guy53 said: Also, why put gusset behind the upright ? I did not, and I never had any problem. Guy Expand Overkill lol.Going to shave it down because I really didn't need it. 1 Quote Link to comment Share on other sites More sharing options...
tony27 Posted February 16, 2019 Report Share Posted February 16, 2019 I added the gusset behind the tubes as well but didn't add 1 in front, rode it a few tmes before adding it as insurance against bent tubes. Are your shock mounts drilled through the tubes & welded both sides like Majesty did? I also ended up adding swingarm extender plates to help with keeping the front down on climbs, haven't come across any negatives to doing this as I'm pretty certain the steering head angle had been altered 3 Quote Link to comment Share on other sites More sharing options...
guy53 Posted February 16, 2019 Report Share Posted February 16, 2019 On my bike, I welded the shock mount on the tube, I have no problem, but I'm not an expert rider so I don't ride as hard as one. Guy 1 Quote Link to comment Share on other sites More sharing options...
Junglejeff Posted February 16, 2019 Author Report Share Posted February 16, 2019 (edited) On 2/16/2019 at 8:56 AM, tony27 said: I added the gusset behind the tubes as well but didn't add 1 in front, rode it a few tmes before adding it as insurance against bent tubes. Are your shock mounts drilled through the tubes & welded both sides like Majesty did? I also ended up adding swingarm extender plates to help with keeping the front down on climbs, haven't come across any negatives to doing this as I'm pretty certain the steering head angle had been altered Expand I made 2 jig plates out of some scrap aluminum t-bar I had laying around.Drilled them a 340mm.I have read that just just putting the longer shocks in the stock holes makes bike real nice handling.I then left one on standard shock mount and used the one on other side of bike to mark frame.I then drilled through the tubes and slid a cold rolled shaft thrue.I marked the shaft and put it in my old harbor freight lathe and machined ends down to 12mm then tacked in place.Using the straight shaft kept everything perfectly in line. Edited February 16, 2019 by Junglejeff Spelling Quote Link to comment Share on other sites More sharing options...
Junglejeff Posted February 16, 2019 Author Report Share Posted February 16, 2019 After I had it fit up I did all the welding on the outside to lock shaft in(no pic of that).The frame bows out some as it goes down so I have the upper shock eyes fit as close to frame as feasible. I cut the shaft off on the inside then went deep and filled with weld.My concern was after drilling frame there was not alot of frame left and I wanted 100% weld contact with shaft and weld to frame.I may have to shim lower shock mounts out a little to make shocks perfectly parallel. Quote Link to comment Share on other sites More sharing options...
guy53 Posted February 17, 2019 Report Share Posted February 17, 2019 I had to shim the lower end of the shock on mine, ao I think you will also have to. Guy 1 Quote Link to comment Share on other sites More sharing options...
Junglejeff Posted February 17, 2019 Author Report Share Posted February 17, 2019 Did some grinding and drilling to pretty it up. 2 Quote Link to comment Share on other sites More sharing options...
