Beta Rev3 2006
MarkLathrope
Having had the bike a couple of days now just going through the fluid levels and replacing etc and general check over before first ride out
I’ve noticed the bottom shock bush swinging arm mounting end is slightly worn are these easy enough to replace ??
also
on the Master cyclinder and clutch cyclinder the rubber boots are worn where is the best place to order replacement parts from around Durham or online ??
thanks
Beta Uk will supply the bits needed. Go to their website, download the parts list/diagram to find the part numbers then go onto the 'shop' site to order. If the rubber boots aren't listed separately then try ebay and I have bought some from BVM. You need to get the correct ones to fit the Grimica master cylinders
