Opinion for a nice start
Nastys
  On 1/15/2019 at 7:40 AM, Nastys said:
...Unfortunately, no dealer around me, big shop with choice are at 7 or 8 hours of road, they have only 125 gas gas or 250 scorpa 2016 ( twenty and factory) have seen a scorpa factory 2018 at 30.min to my home but very expensive. 250 Scorpa haven't a dual map? Soft and agressive mode?
Thanks guys
Expand
Where are you?  The biggest dealer in France (in Europe I think) is Dherby in Valence.  They can deliver anywhere in France.  Their current stock list starts with a Beta Evo at €2970 up to a Sherco ST250 at €3970 - there are 16 250cc bike to choose from.  If you want a 125 (I think you want a 250) they have 2, a Gas gas and a Sherco.  https://www.dherbeymoto.com/marchand/moto_occasion.php?sortby=5andsens=croisandpage=moto_occasion#liste
I am sure they can give you lots of advice and will alter the throttle or add flywheel weights if this is what you feel you need.
I have only just started riding trials and have a 250.  My wife and I share the bike.  I don't think a 125 would be any easier or better, the 250 is not difficult to ride.  The left hand kickstart on the Beta is not a problem - the bike starts very easily.  You can ride the bikes at Dherby before you buy them.  At least if you went there you would be able to look at a very big selection of different bikes and find what you like.
  On 1/18/2019 at 11:33 AM, oni nou said:
IMWO.["No not worthless"] as you are just starting out in trials you are going to drop your bike a lot [If you are trying] and it will get sratched and maybe take some damage .....paying 2000 euro more for a bike will not make you ride any better .....but it could be used to buy a new airbox or silencer end cap if you break them while using the bike....if money pours through your letter box or you have a tree in the garden then why ask the question, if it does not then the 17 GasGas is plenty good enough as would a 2004 GasGas pro be good enough with a bit of work. Whatever you buy still needs to be maintained at cost to you unless you are thinking of changing your bike every 3 months   linklage bearings, fork seals and clutches wear out at the same rate on a 2017/2019 as they do on a 2004 or 2010 etc .........ok that's sense out the way and as every one else will chip in with 2019 bikes are sooooo much better than the 2017 GG as to make them essential to the first time rider its a no brainer.
So that sorts the problem....A 2019 Scorpa it is !......... @nhuskys changed from GasGas 125 to a Scorpa 125 and likes the Scorpa better and he is a 125 specialist so knows things.
Enjoy your new Repsol 260.
Expand
I vote Scorpa 125, but I'm a minority. For some people the technique for starting Gas Gas Pro motor.... even a 125,  can be problematic.There is a thread right now about a 13 year old girl and 5 men who can't start her bike. It isn't the carb or the ignition.... It just seems you are built to start a Gas Gas or you aren't.  I can start any other brand 125 Trials or Enduro bike easily, but not a Gas Gas, hence the Scorpa. If you can test ride one and start it easily, consider buying it. There is one other thing to consider..... The 6 speed dual range Gas Gas Pro transmission doesn't work that well with the 125 riding the loop and trails. You'll find yourself constantly shifting between the gears which have huge nasty grinding change. On a 250 or 300 you would just stay in a higher gear. I can't remember if it is 4th to 5th or 3rd to 4th gear.
@ChrisCH
Yes, I called dherbey...
They are a 8 hours from my home so they think 125 will be fine with my light weight and for start basics.
They have a 2014 gas gas for 3450 euros shipped and a 2019 scorpa racing for 5690 with some reduce on equipment.
An other shop have a 2017 gas gas for 3700 euros ( with new clutch..).
I asked again for a 250, they are not sur fly wheel and long throttle help to have more smooth ride to learn the basic, balance, wheelie, bump and jump on 1 meters box. Asked this question because have a Scorpa 2018 factory at 30 min from my home, like new at 5600 euros.
  On 1/18/2019 at 5:16 PM, Nastys said:
@ChrisCH
Expand
I think you could easily learn on the Scorpa 250.  You can learn balance with the engine switched off.
Have a look at the Laurent Ammazini short videos on YouTube.  There are lots of others in English too, but these are good (helps me with my French as well).
